Author Topic: Speedo  (Read 1312 times)
jon.hunt
Speedo
« on: October 21, 2009, 11:39:32 AM »
Hi All,
        The speedo has stopped on my air cooler,  is there an usual Fault I suspect the speedo Itself, are they easy to repair or have repaired Please,  The cable where does it start  I know it finishes at the speedo head but does it go to a wheel?  or the gearbox and they prone to breakage?
                   Jon.
Re: Speedo
« Reply #1 on: October 21, 2009, 11:53:31 AM »
Mine stopped a while ago, i ran without it for a long time, but since my car has been laid up for so long i decided to investigate.
On inspection, it was immediately obvious that the fault was with the cable. The cable runs from the speedo head unit, through the tunnel, along the underside of the car and finally reaching the tip of the gearbox where it joins the speedo drive. There should be a little bit of the inner cable sticking out of the rubber outer sleeve and this inserts into the speedo drive. Because of the nature of this spinning so rapidly, constantly it does weaken here and they are known to snap. at this point. It is only a 5 minute job to check here - changing the cable is also easy, but very fiddly to route the cable through properly.
Rarely is the actual speedo dial at fault - usually the problem lies with the cable.
