I dismantled the carb today and found that the float seemed to be reaching the top of the bowl, I'm guessing this is why the fuel was leaking out?
I have adjusted the float level, so hopefully that will be better. When I removed the float it seemed to have fluid in it, but there is no where for it to get in or out, is this normal?
The oil looks like it was comming from the rocker gasket after all, when I removed the cover to adjust the valve clearances there is a big noticible tear so it wasn't seated correctly leaving a space for oil to seep out, it also appears to have shrunk..
I did notice that the cover does not meet up with the cylinder head without the gasket, there is a 2-3mm gap is that right?
Iv'e got to wait for a new gasket before I can start it up and check that I have sorted the current issues, a friend lent me his colour tune kit, so hopefully that will help with setting the fuel/air mix.
Once the engine is sorted brakes will be next.
