Author Topic: Getting annoyed at my little Bis  (Read 2086 times)
xXFaiXx
« on: October 10, 2009, 05:30:49 PM »
On the first day I got my little Bis she's been a pain in my backside. First day I got her she broke down because of a siezed water pump so guess what....The head gasket blew. But since then she's been a little thorn in my side. My latest problem is trying to start her or even keeping her going. Sometimes when i try to start her she just goes "click" and doesn't do anything. Other times she tries. But rarely she acctually starts so i can go somewhere. But today she played Havoc with me when she wouldnt start after i had gone shopping and when i acctually got her to start...she cut out 2 seconds later. Anyone got any clue what on earth is going on with my little Bis? I really want to keep this car but she's caused me nothing but problems.
Re: Getting annoyed at my little Bis
« Reply #1 on: October 10, 2009, 06:38:03 PM »
 (-* To the forum, sorry to here your tails of woe...
It sounds like the Engine needs a little TLC, The clicking noise is the starter solenoid not locking into flywheel, so I'd be looking for a replacement as for rest of the faults, new points, condenser, set up the ignition timing + new plugs might help ??? There not expensive but worth while doing if they have not been done, If that does'nt sort it out there could be a fault with the petrol pump or there could be dirt in the carb which will need cleaning out.
It sounds alot but should only take a competant Mechanic 1 to 2 hours to sort it.
A couple of important things to do...
Remove the thermostat.
Bleed the water system.
Clean the oil filter.
Make sure you have a clean fuel filter on the petrol line upto the pump.
Most important make sure the person who's doing the job knows what they are doing.
Technical data in the download section on the front page.
Hope this helps. Pete.
Wee Red Motor
« Reply #2 on: October 10, 2009, 11:44:09 PM »
Hi, sorry to hear about your BIS but I think that this is par for the course with these cars.
I'm new to these cars - too much Vodka & Redbull and Ebay don't mix !!!
When I got mine it was also a bad starter with poor idle etc etc.
The clicking and non starting is a symptom I have too but I just retry and next time it works. Just waiting till the starter motor fails completely before I replace.
I have just gave mine a good service :-
All fluids, filters, plugs, condensor, points, valve clearances. It runs better now.
The carb needs a good service - overhaul kit and I'm hoping that will cure the lumpy idle and I can adjust the idle speed down abit which is screwed up to even the idle a touch.
It's worth a look at your carb - take off the air inlet from your aair filter housing and check your choke is working when you pull the choke lever and also going off when you want it too - mine is very worn and has given me some grief.
I also have moments when I really don't feel the faith and the tag of Fix It Again Tomorrow (FIAT) is well placed.
« Reply #3 on: October 12, 2009, 12:28:48 AM »
I don't have a Bis so the other guys can give you more advice on the water problems, I have an aircooled. As for the non starting etc, when you say she cut out 2 seconds later, how did it happen? Did all electrics die (dash lights)
If you have a bad earth connection, it can be a pain to start, sometimes it never starts. When it doesn't start, if the lights are on, they dip as the starter clicks. If it does start when it cuts out everything dies as there is no connection. If this sounds familiar, then connect a jump lead from the -ve battery terminal to a solid non painted part of the car, then from the engine to a solid non painted part of the engine bay and see what happens.
let us know how you get on.
Michael
