Fiat 126 Chat
Front nearside wheel bearing
Pages: [
Topic: Front nearside wheel bearing (Read 1737 times)
Manxbis
Newbie
on:
October 07, 2009, 01:12:11 PM »
Do I need any specialist equipment to change the front nearside wheel bearings, for instance are they pressed into the hub?
Regards
Steve
Subscriber VIP+
Re: Front nearside wheel bearing
Reply #1 on:
October 07, 2009, 01:40:50 PM »
Yes they are a light press fit but it is quite easy to drift them out. I use a bit of old mild steel bar & work around the circumference with gentle taps working from the opposite side of the housing. New ones just tap or press in [-/
Manxbis
Newbie
Reply #2 on:
October 07, 2009, 06:48:33 PM »
Thanks for that, I will have a go this weekend.
Manxbis
Newbie
Reply #3 on:
October 18, 2009, 11:01:17 PM »
Bearing changed and seems OK at the moment, used a bit of tube as suggested, many thanks
Pages: [
Fiat 126 Chat
