Author Topic: my new brakes are squealing.. anything I can do?  (Read 1707 times)
phreak97
  • Niki!
« on: October 03, 2009, 08:38:49 AM »
I've just put new brakes in today, but im getting lots of burning smells and they squeal when I brake.
I put new drums in as well, I shouldnt have to machine them from the factory should I ? I got standard drums and shoes
phreak97
nrg19uk
Re: my new brakes are squealing.. anything I can do?
« Reply #1 on: October 03, 2009, 06:04:41 PM »
you may have had a bit of grease or oil on your hands which has gone on the drum or shoes it should go with time.
 its also important to use a good brake cleaner to wipe the drum down before fitting especially new drums because they coat them in a very fine oil/teflon coating to prevent rusting.
plus they take a bit of time to bed in
Neil gargaro
« Reply #2 on: October 03, 2009, 06:46:32 PM »
try feeling the wheels after a journey (no heavy braking) just to see if the wheels/brakes are getting hot.
If they are or have different temperatures it would suggest that you have some kind of problem.
phreak97
  • Niki!
« Reply #3 on: October 04, 2009, 01:06:04 AM »
well I had smoke coming from the front left, so I think that indicates theyre getting hot..
I wiped the drums down with thinners, and i tried not to touch the shoes with dirty hands.. they were a pretty snug fit, but I kinda hoped that would sort itself out if I jumped on the brakes a few times in forward and also reverse, the auto adjusters are too hard to put in the right place manually.
how long should it take to bed in?
edit:
I just took it for a drive probably about 2km around my area and the brakes didnt heat up, I am getting an intermittent clicking from the front right while braking though.. would that just be the shoes moving around while theyre sorting themselves out?
the brakes also arent as nice as I expected them to be, the pedal isnt particularly hard even though we got a steady stream of new fluid through all four wheels. I did put a new master cylinder in, was there anything special I was meant to do to prime it? I got fluid through it before I connected the brake lines to it.
« Last Edit: October 04, 2009, 01:41:27 AM by phreak97 »
phreak97
« Reply #4 on: October 04, 2009, 11:03:08 PM »
When replacing brake shoes put a chamfer on the leading edge, This helps bed them in quicker.
to adjust the self adjusting brakes, drive forward and brake hard, do the same in reverse repeat a couple of times then do the same again just using the handbrake, you should be able to feel the brake pedal come up ;)
