Author Topic: Bonjuer mes amis - Ignition Electronic !  (Read 3953 times)
« on: September 23, 2009, 05:31:55 PM »
OK so that is about as far as my french goes but In was interested in the mention of a DIY electronic ignition that was picked up on another French Fiat 126 web site. So could be useful if any of you guys out there can read french & know a bit about electronics  [-/
Link shown below
http://ilcubopiccolo126.free.fr/dos_tec ... umAE9C.htmpaganini88
Eklipze3k
Re: Bonjuer mes amis - Ignition Electronic !
« Reply #1 on: September 23, 2009, 05:37:02 PM »
Monsieur, your hyperlink - she is broken! Mon dieu!
« Reply #2 on: September 23, 2009, 06:49:42 PM »
Sacre Blue  :o
All I did was cut & pasted the link from the Fiat500club chat section & it is at the end of the thread that starts with the title "carb spitting out gas" I must have screwed it up somehow as it works from there.
« Reply #5 on: September 23, 2009, 08:49:03 PM »
cest quoi cette truc de merde!! vous etes oblige a fabriquer une boite etanche et tous le carte de circuit a main ou achette un version differente pour 70 euros!!
 vive la france! vive la revolution! vive les merguez frites avec kronenbourg!!
prkahrvat
  • PEGLATRON
« Reply #6 on: September 24, 2009, 12:35:40 AM »
Ok im sorry again for my bad english and bad enlish translation, but is this electronic thing that guy made working and is it smart to put that in car, another question is i have newer version of 126 and will it be good in newer version, this is easy to make, and i dont think its expencive, ill go tommorow see how much parts are cost.
Sorry for bad english!
« Reply #7 on: October 05, 2009, 06:38:56 AM »
All gone quiet on this one , where are all the anglo/french electronics fanatics  ???
« Reply #8 on: October 05, 2009, 09:32:10 PM »
from what i read it is a grey area as you really need to be a cottage industry electronics whizkid after all can you fabricate your own circuit board?! it stops the points wearing so makes it more acurate and ecconomical however its bloody hard to make and then you can always buy one from the bod mentioned in the post.
« Reply #9 on: October 05, 2009, 10:06:57 PM »
A little expensive. Maplins do a velleman kit £9.99 HERE
This the how you wire it in a 126
« Reply #10 on: October 05, 2009, 11:24:21 PM »
In my last place of work there was an electronics guy who could knock up a pcb over lunch if you asked him nicely!
You can use one of these:
http://www.maplin.co.uk/Module.aspx?ModuleNo=1922
just solder in the components and cut away the tracks to suit. You can make a double sided board if you like.
That £10 kit from Maplin isn't too bad though, if you consider how long it takes to solder  and assemble.
I have been looking at replacing the points with a hall effect sensor. Found one in RS for about £4. It looks like it can be bolted onto the base plate although it means I'll have to have a few parts machined and I'm not sure how much that will cost yet.
The beauty of the hall effect sensor is it doesn't reduce contact degradation, but eliminates by by removing all points of contact (see what I did there!!)
The only thing it leaves behind are the bob weights.
« Reply #11 on: November 03, 2009, 09:43:11 PM »
Proeitti and Ricambio International sell electronic ignition kits. It is not cheap but these guys swear by it. It improves performance (no flat spots) and fuel consumption and most of all it makes the car reliable , so maybe worth the expense. Has anyone tried this?
