Author Topic: HELP!!!! HELP!!!!  (Read 1381 times)
Alex
HELP!!!! HELP!!!!
« on: September 21, 2009, 09:35:39 AM »
Hello,
i need some advice regarding my BIS, i finally got her running after changing thermostat, new master cylinder, etc, but when i try and pull away/reverse there is no real power in the engine, even with my foot to the floor in first gear i could not go more than 5 MPH! has anyone experienced this type of problem before?
could it be a problem with the carbuerretor?
could it be Master Cylinder
any advice or help will be greatly appreciated,
Alex
Re: HELP!!!! HELP!!!!
« Reply #1 on: September 21, 2009, 09:43:19 AM »
What symptoms? engine not revving? does it rev ok when the car is not moving?
Alex
« Reply #2 on: September 21, 2009, 12:14:09 PM »
Yeah the engine revs fine when ticking over, and when i apply the accelerator, the engine again revs up, but there is a serious lack of torque coming from the engine, i dont think it is revving enough, when flat to the floor in first gear, the engine also tried to cut out, like there was to much petrol being fed into the engine!
hope this info helps
cheers
