Author Topic: Changing the door glass mount  (Read 1752 times)
Aaron
« on: September 21, 2009, 05:45:09 AM »
G'day,
One for the forum's brain trust.  Only my Niki (FSM 126) the passenger door glass has been installed back to front, which means there's a 'bit' of a gap at the front when the window is wound up.  I'm guessing that somone previously has installed a driver's side glass into the wrong door.
So now having what I expect is two driver's side door glasses, I'm wondering how you turn the small metal channel around on the base of the glass such that I can turn the glass around and have the winder work.  This is on pretty damn tight and I'm not wanting to force it.
My parts car had the door glass missing unfortunatley.
Re: Changing the door glass mount
« Reply #1 on: September 21, 2009, 11:16:19 AM »
I think that you may be struggling there as the windows are not symetrical plus they have a slight top to bottom curve.  :(
Aaron
« Reply #2 on: September 22, 2009, 05:06:44 AM »
Ah ha, ok so the left and right side are different pieces of glass then?  That's a bugger, it looked flat initially. :(
« Reply #3 on: September 22, 2009, 12:13:53 PM »
 :) If you can't get a replacement down there then pack one in a suitcase next time you or one of your mates fly into London  [-/
