Author Topic: Engine will not idle.  (Read 1453 times)
Funkin Go-nut
« on: September 18, 2009, 12:52:00 PM »
The engine will fire with bit of coaxing and will run fine on the throttle, if I lift of the engine dies..
The choke doesn't work at the moment (lever seems to pull the outer sheath rather than the cable..) plan to fix that next..
What are the likely causes of this problem.
FGN
prkahrvat
  • PEGLATRON
Re: Engine will not idle.
« Reply #1 on: September 18, 2009, 02:01:37 PM »
Try to read this topic mybe it help: carby flat spot:(
Sorry for bad english!
« Reply #2 on: September 18, 2009, 09:25:44 PM »
how low is the idle? you could always tweak it up a little to get it running?
Funkin Go-nut
« Reply #3 on: September 18, 2009, 09:28:37 PM »
I just want to get some ideas before I start to fiddle with it :)
