Author Topic: carby flat spot:(  (Read 2559 times)
phreak97
  • Niki!
carby flat spot:(
« on: September 17, 2009, 05:32:36 AM »
since I've had it I've had to press the throttle in slowly because if I press it quickly the engine almost dies, or does die if it's cold.
what can cause this? I've just cleaned out the whole thing with carby cleaner and compressed air and it didnt help. flat is adjusted as per the manual, but it works better if the float level is higher.. so I guess the fuel supply is insufficient when the butterfly first opens.
any ideas?
cheers
phreak97
prkahrvat
  • PEGLATRON
Re: carby flat spot:(
« Reply #1 on: September 17, 2009, 11:00:36 AM »
i have same problem but i first let car to warm up a bit then start to drive without a choke. i think if you have choke and press throttle, too much of mix of gas and air is coming to engine and its not flamable enough. its my opinion....
Sorry for bad english!
phreak97
  • Niki!
« Reply #2 on: September 17, 2009, 10:38:46 PM »
mine's always there, it varies a little dfepending on temperature, but it doesnt go away..
phreak97
prkahrvat
  • PEGLATRON
« Reply #3 on: September 18, 2009, 12:26:10 AM »
maybe try to unscrew gas mixture but only a bit, or if its unscrewed too much screw it but not maximum, try to look valves too. inlet must be 0.25mm and exhaust 0.2 mm (0.1inch and 0.08inch). that may be the problem.
phreak97
  • Niki!
« Reply #4 on: September 18, 2009, 08:04:38 AM »
all done with no change:(
phreak97
« Reply #5 on: September 18, 2009, 08:55:54 AM »
It may be worn, maybe a new carb?
phreak97
  • Niki!
« Reply #6 on: September 18, 2009, 11:19:57 AM »
I've got another one I'll try, but it's off a working motor that's slowly been having its bits stolen, Kinda didnmt want to just put a heap of broken bits into it..
phreak97
prkahrvat
  • PEGLATRON
« Reply #7 on: September 18, 2009, 11:26:21 AM »
hmmm did you try to exchange air filter? little chance for this but try. is your fuel pump working good? try to look when you start engine how the fuel pump is working. Is there enough gas comin in carb?
phreak97
  • Niki!
« Reply #8 on: September 18, 2009, 01:37:41 PM »
I have replaced the air cleaner, but it does it with the pipe off too so it's not air restriction.
the pump works, I had a fair puddle of fuel everywhere when I forgot to put the return line back on.
phreak97
prkahrvat
  • PEGLATRON
« Reply #9 on: September 18, 2009, 01:59:43 PM »
then must be the carb....
defender90
« Reply #10 on: September 18, 2009, 10:30:45 PM »
 Sounds like it may be running too rich?
Kevan
Radcliffe
Gt.Manchester
Citroen BX TDG (soon to go)
Citroen BX TZD
Land Rover 110 Station Wagon
« Reply #11 on: September 18, 2009, 11:52:28 PM »
I had the same problem and found it went away when I dropped the float level a little.
There is a webber website somewhere that suggested it, can't remember where  :oops:
phreak97
  • Niki!
« Reply #12 on: September 19, 2009, 12:19:54 AM »
that's odd, it got better when I RAISED the float level :S:S
I think it definately is the carb, I'll play with the float level some more, but ill be suprised if that's actually the problem.
phreak97
