Author Topic: Extra air cooling!  (Read 1526 times)
Extra air cooling!
« on: September 16, 2009, 09:55:46 PM »
I picked up some bits from Jan and in the box was a device to keep the top of the engine cover open probably by about 6-8 inches.
I have seen Mick had one so figured I'd give it a go.
Just been to Lymington (from Southampton) and back, about 60 miles in total which is a regular trip for us as mum in law lives there, and usually I find the car struggles a bit on the return trip as the run up the M27 to where the M3 joins is a bit of a long uphill struggle, she starts to loose speed, down to about 55 mph then starts to 'pink' which is like a ticking noise which gets worse the more I try to push her, and a few evenings ago it lost so much power I saw the speedo drop to 40!
It's odd as the 'pinking' doesnt occur all the time on uphill sections. Mick set my timing the last meeting we saw him so figured it wasnt that.
After fitting the device to keep the engine cover open, wow what a diference!
No more 'pinking' she held 65 mph and cruised at about 70 on a slight uphill.
The confusing bit now is why my fuel consumption is more or less exactly the same...
Anyhow off to see an expert in all things carburettor and injection tomorrow so might end-up with a 'flux capacitor' !!
Re: Extra air cooling!
« Reply #1 on: September 17, 2009, 10:46:21 PM »
sounds like your engine is getting too hot under load from what you describe so a bit of extra heat loss /air flow is a good thing.
markie
« Reply #2 on: September 21, 2009, 03:49:45 PM »
Hi guys, I've got an X/19 rusting to the driveway and have noticed that this uses an extra electric blower to accelerate the airflow into the filter.  I was thinking of grafting it onto my aircooled 126 maybe between the air filter and the carb using a seperate filter for the air intake is this silly or should I go for it??  more power???
« Reply #3 on: September 21, 2009, 09:35:16 PM »
I'd go for it but put it on a switch so as to see the effect while on the move.
Who knows, you could have the makings of a 126 BOOST ! [-/
