Author Topic: Running Rough , the Old Air Cooled Problem  (Read 1972 times)
« on: September 10, 2009, 02:05:41 PM »
I had noticed a drop off in performance & a little misfire recently after almost a year of smooth running (ignoring the fitting of a new clutch) then this morning it took a turn for the worse. Suspected the fuel side as I have the 123 electronic ignition fitted. Got to my destination & had a quick check . First thing I did was check that the carb mounts were secure.
Oh my word !! :oops: The carb had worked so loose that I was surprised that the engine ran at all. I have had this problem before & a quick flick with a 10mm spanner had the little beast humming again. I was a little surprised as It was held with brand new Nylock nuts & I suspect that the studs have loosened in the head itself. Not hard to fix  but a tricky little area as if you try & compensate by over tightening the nuts you end up bending the flange at the base of the carb  :cry:
Re: Running Rough , the Old Air Cooled Problem
« Reply #1 on: September 10, 2009, 09:11:04 PM »
owning an aircooled fiat lesson no6. always have an "assortment of nuts" in your trouser pocket.......
« Reply #2 on: September 10, 2009, 10:57:14 PM »
threadlock the stud to the head, pick a threadlock with a high break force so the nylock doesn't shift it
« Reply #3 on: September 10, 2009, 11:30:05 PM »
this statement worries me on so many levels mick... ;D
phreak97
  • Niki!
« Reply #4 on: September 11, 2009, 02:04:27 PM »
I had to bail my friend out of trouble once, he'd managed to splutter to work and then it wouldnt start when he wanted to come home. so I drove half an hour out to him at 10:30pm to find I could lift his carby up about a centimeter before it hit the nuts:P I told him I was suprised he'd got there to begin with.
phreak97
« Reply #5 on: September 11, 2009, 02:56:47 PM »
 :) I know that the old air cooled engine is often criticised for its crude design but bearing in mind that it was designed well over 50 years ago , you can still get all of the parts quite easily , it ain't done so bad & it is remarkable that it will still run up until the point that the carb pretty much falls off , thank heavens for gravity ! :oops:
phreak97
  • Niki!
« Reply #6 on: September 12, 2009, 01:34:50 PM »
I have a lot of faith in simplistic designs. it is pretty amazing how they can keep going with the carby held on by gravity and a bit of manifold vacuum. I guess thats why they can keep running past the point where theyll start again, the vacuum holds it in place. the starter motor cant spin the motor fast enough to suck the carby down.
phreak97
