Author Topic: Indicator Flasher Unit  (Read 1559 times)
jon.hunt
« on: September 08, 2009, 04:00:43 PM »
Hi All,
         I would like to change my Thermal Flasher unit for an Electronic one, wondered if anyone knows what will work Please,  I've tried a Lucas SFB190  Doesn't Work!!!!!, Also my Daughter has passed Her Driving test so the 126 is now Shared******
                                                    All the Best        Jon.
Re: Indicator Flasher Unit
« Reply #1 on: September 08, 2009, 05:00:25 PM »
Hi Jon, Is there a reason for wanting to replace the flasher unit for an electronic one ??? When you can buy a universal round 2X21w+6w for about a fiver.
« Reply #2 on: September 08, 2009, 06:09:47 PM »
 :) The electronic one is needed if you fit LED bulbs as the current flow is not enough to kick the flasher unit into action. Thought about trying them but that would then leave me with a couple of hundred original type bulbs in my garage , Dad was an Auto electrician  :oops:
« Reply #3 on: September 08, 2009, 08:53:36 PM »
I bought a full set of LED replacement bulbs sidelight (4 LED Type) stop&tail (36 LED Type) indicators (36 LED Type) with the electronic relay and resistors, Spent an afternoon fitting them, they all worked, but were very hard to see in Daylight and impossible to see in bright sun light, In my opinion Dangerous and a complete waste of money, the next day i put all the original bulbs back in.
Modern LED car lights are designed to cover the hole area of the rear lens and work very well, but using them with the original light unit does'nt work.
defender90
« Reply #4 on: September 08, 2009, 10:33:56 PM »
Thanks for that advice Pete, that'l stop members waisting their money. i'll pass that on.
Kevan
Radcliffe
Gt.Manchester
Citroen BX TDG (soon to go)
Citroen BX TZD
Land Rover 110 Station Wagon
