Author Topic: Non starter  (Read 2047 times)
Jayne126:D
Non starter
« on: September 08, 2009, 02:04:14 PM »
Hello,
Ive been driving my Bis around all morning with no probs and ive left it for a few hours and just come back to it and it won't start at all.
When i turn the key the lights are coming on but thats it, no noise fom the starter motor or anything.  We got it going with a push start, but as soon as we stopped and tried again, nothing  :(
Any-one got any suggestions of what i should check first? And how?
Re: Non starter
« Reply #1 on: September 08, 2009, 05:09:26 PM »
Hi Jayne.
There should be 2 wires connected to the starter motor a thick red one which is held in place with a big nut, and a thin one with a spade terminal on, check that the thin wire is connected and has'nt come loose. If this is'nt connected it won't activate the solenoid on the starter when you turn the key to the start position.
Jayne126:D
Re: Non starter
« Reply #2 on: September 09, 2009, 07:36:12 AM »
Hi Pete, thanks for your reply.
I've had a look at this and the thinner wire seems to be connecting fine, Is a bit wobbly but seems to clip in tight enough and it doesn't look rotten or anything like that. Do you think i should have a go at replacing the spade terminal anyway just in case it is a connection problem? If its not this connection then do you think it could be a problem with the starter motor itself?  :(
Re: Non starter
« Reply #3 on: September 09, 2009, 08:08:08 AM »
Disconnect the thin wire and put a meter/bulb tester from the wire to earth, get someone to turn the ignition switch to the start position there should be 12volts on that wire, if there is'nt the fault is from there to the ignition switch,
If there is 12volts its got to be the starter motor/solenoid.
Dan_535
Re: Non starter
« Reply #4 on: September 09, 2009, 04:12:03 PM »
The Starter could have jamned, if after the electrical test you find there is power going to the starter try turning it over with someonelse simultaneously tapping the starter gently with a spanner/small hammer (ideally with a small piece of wood between starter and hammer to spread load of tapping- to avoid damage to the starter housing), after a light tap (or 10!) it might turn over and start, obviously get starter and bushes replaced ASAP if this is found to be the problem...
Good Luck
Dan
Jayne126:D
Re: Non starter
« Reply #5 on: September 26, 2009, 03:17:33 PM »
Hi guys,
Just to say thanks for the advice, turns out it was the starter motor. We replaced it yesterday and now old biscuit wheels is back on form and i don't need to get the chav wagon to work anymore. Happy days!
Thanks again for your help :D
