Author Topic: problem with starting engine  (Read 2848 times)
prkahrvat
  • PEGLATRON
« on: September 06, 2009, 07:00:54 PM »
my problem is when i am starting my 126 aircooled, it is starting about 40-50 seconds and then engine start. after i start it, engine works perfect and when i start engine second time it start perfect. but after 5-6 hours when engine get cold same problem begins. starter motor is on 10°, valves are on 0,20mm inlet and 0,25mm exauhst. gas pump works perfect and carburator is new, i changed even piston rings and problem is still here. battery is 45Ah(even stronger than normal) and alternator works fine....
Sorry for bad english!
Re: problem with starting engine
« Reply #1 on: September 06, 2009, 08:17:55 PM »
plugs? have you checked them?
prkahrvat
  • PEGLATRON
« Reply #2 on: September 08, 2009, 11:17:32 AM »
new
« Reply #3 on: September 08, 2009, 08:44:18 PM »
did you set the plug gaps yourself ? i always find it best to go as wide a gap as it allows within the guidance, also just a thought but do press the clutch pedal down before you try to start the motor?
prkahrvat
  • PEGLATRON
« Reply #4 on: September 09, 2009, 12:29:41 PM »
hmm... good idea for clutch! only problem is i dont understand english so good and i didnt understand plug gaps. is it on ignition and is it angle or gap between breaker points?
« Reply #5 on: September 09, 2009, 07:51:22 PM »
its the gap on the spark plugs (gordan translate if needed!!)
prkahrvat
  • PEGLATRON
« Reply #6 on: September 10, 2009, 12:08:09 AM »
clutch didnt help, and gap in spark plugs are 0.5 mm (~ 0.2 in)... what would happen if i increase gap between valves? now is inlet 0.2 mm (0.079in) and exhaust 0.25mm (0.1 in).
« Reply #7 on: September 10, 2009, 11:03:30 AM »
Try changing your high tension coil, it made a world of difference to me...
/probaj promijeniti bobinu po mogućnosti s novom, meni je poboljšalo paljenje/
prkahrvat
  • PEGLATRON
« Reply #8 on: September 10, 2009, 11:48:52 PM »
changed first and didnt work, after that buyed new one didnt work.... i think that problems may be in valves
phreak97
  • Niki!
« Reply #9 on: September 11, 2009, 01:59:27 PM »
I thought the valve gap was meant to be around 0.4mm.. maybe you aren't getting enough compression.
are you using the correct coil? the green wire to the coil is resistive, so if you chose a coil that needs 12v directly it wont work properly, you need one that requires a ballast resistor.
is your choke operating correctly? make sure that when the lever is all the way up the choke is fully on.
How well does the car run once it starts? does it seem like it might have fuel problems?
phreak97
prkahrvat
  • PEGLATRON
« Reply #10 on: September 12, 2009, 05:00:15 PM »
im sure i will first try to change valve gap to 0.4 and 0.45 mm and see what will happen. i dont think the problem is in coli because car worked fine and now not and coil is same. dont think that problem is in something with fuel because after i start car it work perfectly whole day, even if i try to start again it start in first try, but next morning when engine is totaly cold problems start. i know its harder to start cold engine but not like this. this sounds like torturing my car and not starting engine. i will sure try valves if not today , tommorow. thank you!
« Reply #11 on: September 12, 2009, 11:26:57 PM »
your valves should be .20 inlet and .25 exhaust , plugs are .6 to .7 , if you have someone to help you make a mark on your distributor so that you can realign it back to its previous setting and try loosening the distributor and if the engine is not firing move it back slightly to see if that helps if not go forward as it might be slightly out of time it only takes a bit to make it hard to start.
prkahrvat
  • PEGLATRON
« Reply #12 on: September 13, 2009, 02:20:02 AM »
turning valves on 0.4 didnt help, next mission is to try set distributor on 5°, 15° and 20°. if that doesnt help im putting new engine!
