Author Topic: Brakes  (Read 2136 times)
Funkin Go-nut
Brakes
« on: August 31, 2009, 10:26:05 AM »
Are the front and rear brake shoes and cylinders the same on the front and rear of the early 126's?
FGN
Re: Brakes
« Reply #1 on: August 31, 2009, 12:15:06 PM »
 :) HI FGN , Shoes are the same back & front (not sure about the Bis) but cylinder diameter is always smaller on the back to give a little bit more grunt on the front. Being 1980 your car is not an early 126 (594ccs engine) so be carefull when you get parts as the cylinder bore increased from the Fiat 500s up through the range & all of them have the same mounting. Yours should be 15/16" front & 3/4" rear  [-/
Funkin Go-nut
Re: Brakes
« Reply #2 on: August 31, 2009, 12:17:28 PM »
Thanks, learning more everyday  [-/
Dan_535
Re: Brakes
« Reply #3 on: August 31, 2009, 09:56:22 PM »
the brake drums/shoes were increased in size from 1977, a 1977-1982 set of shoes should see you right (possibly even on from there)...
Funkin Go-nut
Re: Brakes
« Reply #4 on: September 01, 2009, 07:29:18 AM »
Does that mean you could put the larger cylinders on the rear to get a better balance if you went for the front disc conversion?
Re: Brakes
« Reply #5 on: September 01, 2009, 07:47:34 AM »
 :) Yes , with discs on the front you can go for the larger cylinders at the back which is about as good as you can get short of doing a rear disc conversion as well or fitting a servo. You will certainly notice the difference in stopping power  [-/
