Author Topic: CAMSHAFT WANTED  (Read 2371 times)
CAMSHAFT WANTED
« on: August 25, 2009, 08:57:42 AM »
 :) I am about to start re assembling a Fiat 500 engine & I thought it would be interesting to try a 126 camshaft so if there is a spare one out there I could well be up for it. Would consider an engine or part of. One very generous member from the forum sent me one already  [-/ but it was from a 594ccs engine & it turned out to be exactly the same as the older 499ccs one  :cry:
landyman
Re: CAMSHAFT WANTED
« Reply #1 on: August 25, 2009, 05:17:54 PM »
can let you have one but away on holls back sat 5th sep don't know if you can wait that long but welcome to try a 650 one,should be able to post sometime mon 7th.if not happy hunting    andy
Re: CAMSHAFT WANTED
« Reply #2 on: August 25, 2009, 05:45:41 PM »
 :) Hi Andy , I am not in a real hurry so that would be no problem but I would not like a good engine to be broken just for the camshaft so I hope that would not be the case. I see that you are like me , can't stay away from the forum even when you are on your hols  ;) cheers mate  [-/
landyman
Re: CAMSHAFT WANTED
« Reply #3 on: August 25, 2009, 07:34:38 PM »
leaving in early hours 26th unless i find internet cafe won't be on the forum for 10 days will be climbing the walls with bad withdrawal symptoms, engine unknown quantity needs stripping, will get in touch on return.    ps.been watching forum since x-mass only just noticed in your baby 500 whats going on with darth vader and the emperor???
landyman
Re: CAMSHAFT WANTED
« Reply #4 on: September 07, 2009, 12:55:42 PM »
hi rusty back now have sent you a pm
Re: CAMSHAFT WANTED
« Reply #5 on: September 08, 2009, 11:54:18 AM »
Hello mate , there must be a glitch in the works as no no PM received 24+ hours on  :oops:
landyman
Re: CAMSHAFT WANTED
« Reply #6 on: September 08, 2009, 11:35:17 PM »
have sent contact details hopefully ? :oops:
landyman
Re: CAMSHAFT WANTED
« Reply #7 on: September 09, 2009, 05:53:51 PM »
hi rusty, pm's not getting through to you ring me on 07917 823823 hope this works!
