Author Topic: Washing...  (Read 1840 times)
Josip
    • JoeXmas Photo
Washing...
« on: August 18, 2009, 11:36:59 PM »
Not actually mechanical problem, but it might become one...
I got my 126 today, i checked it, works fine, quiet... now the thing i want to do i wash its machine, it has some oil on it, some grease spots, some mud and generally dirt...
Did you ever washed your machine, and do u use some chemicals or like mini wash? Im scared that i dont mess up something mostly power and other stuff ?
Eklipze3k
Re: Washing...
« Reply #1 on: August 18, 2009, 11:50:35 PM »
If you can get Autoglym Engine and Machine Cleaner you should be able to use that quite easily. Disconnect the battery first to prevent any accidents, spray it thoroughly all over the engine and engine bay, leave for a few seconds and then agitate with a stiff brush. Then just rinse off.
Obviously leave it to dry thoroughly before reconnecting the battery and trying to drive it again ;)
Re: Washing...
« Reply #2 on: September 08, 2009, 11:45:20 PM »
Josip, i washed my engine, (it was out) with a chemical called supermafrasol, i bought it in Getro C&C, round 50kn, its awesome, you just spray it on, wait, and wash it off. simple as that  [-/
phreak97
  • Niki!
Re: Washing...
« Reply #3 on: September 11, 2009, 02:09:47 PM »
I've taken my car through the self serve car wash things a couple of times, both times it came out on one cylinder, and that was without even cleaning the engine, just the pressure cleaner over the engine cover got enough in there apparently.
it wasnt water in the dizzy like I had expected, it was water through the coil connections, the spark liked going through the water to the chassis better than down the leads.
so just be careful spraying your coil and also your distributor if you can help it, maybe put plastic bags over them or something. everything else should be fine. if it doesnt work right afterwards just pull your leads off and make sure everything is dry.. worked for me.
phreak97
