Author Topic: Petrol & Air  (Read 1700 times)
Alex
Petrol & Air
« on: August 18, 2009, 01:31:34 PM »
Hi, Me again :)
as my fuel tank is full of crud!!! i want to fit a filter onto the fuel supply line, does anyone have a picture of this so i can use as a guide?
Also i have heard rumours of putting a different air filter onto a bis, is this true?
Re: Petrol & Air
« Reply #1 on: August 18, 2009, 01:42:01 PM »
just stick it in between the fuel tank and the fuel pump that way it stops crud getting into the pump. as for different air filters for the carb thats all down to how you want to do it and where you want to put it!
Alex
Re: Petrol & Air
« Reply #2 on: August 18, 2009, 02:04:53 PM »
cool,
cheers for the answer,
Alex
Dan_535
Re: Petrol & Air
« Reply #3 on: August 18, 2009, 07:02:21 PM »
Hi Alex
your best bet is to drain and clean the tank out, then get an in-line fuel filter and few feet of  new hose and some fuel line clips (loads of kits with everything you need on e-bay etc) so you can renew the fuel line as a whole
Fuel hoses have a habit of cracking with age, especially if the car has been laid up for a while, for safety sake it may be as well do do the lot as its not that expensive to do.
Dan
