Author Topic: BIS Flywheel  (Read 2161 times)
fly
BIS Flywheel
« on: August 12, 2009, 10:42:05 PM »
Has anyone got a spare BIS flywheel knocking about they would like to part company with? - or alternatively know of anywhere that sells BIS flywheels, or even just a manufacturer of flywheels who might beable to knock a tasty light weight one up?...just a standard one would still be nice though.
Cheers.
Re: BIS Flywheel
« Reply #1 on: August 13, 2009, 07:32:39 AM »
I do not have a Bis flywheel here to prove it but I reckon it will be the same as the aircooled cars. I have a 500 stripped down at the moment and could give you details if you wish . It will at least open up the possibilities for you  [-/
fly
Re: BIS Flywheel
« Reply #2 on: August 13, 2009, 10:07:10 AM »
You are good man to know.
Ill put a tape over my existing flywheel tonight - might even go as far as to count the teeth.
Re: BIS Flywheel
« Reply #3 on: August 13, 2009, 11:11:19 AM »
There are reports that the Fiat 500 flywheel is lighter than the standard 126 flywheel.
Anyone confirm if this information is correct?
Re: BIS Flywheel
« Reply #4 on: August 13, 2009, 11:23:39 AM »
 I also red about it somewhere. I will try to find the article...
Re: BIS Flywheel
« Reply #5 on: August 13, 2009, 12:00:15 PM »
 :) No good counting my teeth I ain't got many left  :oops:
Oh you mean on the starter ring  ;)
Just been up the shed with the bathroom scales & the 500 flywheel weighs in at about 12 to 13 lbs  [-/
fly
Re: BIS Flywheel
« Reply #6 on: August 13, 2009, 08:31:35 PM »
Just had a weigh and measure, overall diameter is 265mm and weighs in at a hefty 14.6lbs and a crack in the bathroom scales; from the ring gears i've seen for sale I think that makes it 25mm wider/girthier (which isnt a word) than an aircooled's.
