Author Topic: Fuel Supply Problem  (Read 1691 times)
Fuel Supply Problem
« on: August 08, 2009, 01:18:12 PM »
Driving at high speed the car will die then come back, but drive at 40ish all OK.  Therefore I assumed a fuel supply problem, had something similar on my 500 that turned out to be the pump drive pin from the camshaft was worn.  All seemed to check out OK then noticed a lot of air bubles coming from the petrol tank to the pump, thought it might be rust damage to the outlet pipe from the tank.  Cut an inspection hole in the seat area to view the sender/fuel supply unit and sure enough the outlet pipe is corroded but no signs of damp, the tank is 3/4 full.  Is this a common problem any ideas of what is wrong do I need a new sender/fuel supply unit and if so where can I buy one.
Re: Fuel Supply Problem
« Reply #1 on: August 08, 2009, 06:38:06 PM »
 :) Hi Ralph , I have got a tank with all the bits that have been in my dry shed for about 15 years if you need anything  [-/
« Reply #2 on: August 08, 2009, 08:58:52 PM »
Hi Rusty, looks like the air leak is in the tank, need to remove the sender unit to check.  All the nuts and studs are severly corroded and may break when I try to loosen.  I will give it a go tomorrow.  I will let you know how it goes.  We are hoping to attend Hopetoun House meet next weekend if all goes well.
Paul632
« Reply #3 on: August 17, 2009, 10:44:13 PM »
My sender unit had a totally blocked filter on it's delivery pipe, when I got the car.Had to replace my whole sender though as the variable resistor for gauge had gone open circuit.The car had been dry stored for 12 years with the old fuel in tank all that time.The screen filter was totally lacquered  up !!
Have you checked the gauze on the carb banjo fitting ?
