Author Topic: 3rd gear  (Read 2305 times)
rudi van disarzio
3rd gear
« on: August 02, 2009, 01:04:43 PM »
can anyone help?bis has been running great but has now constanly started to pop out of third gear all other gears are fine really worried it serious.plz help!!!
Re: 3rd gear
« Reply #1 on: August 02, 2009, 01:14:19 PM »
sounds like its gonna mean some gearbox surgery find another box before this one goes i doubt if the adjustment is out as it engages but pops out .
rudi van disarzio
Re: 3rd gear
« Reply #2 on: August 02, 2009, 01:39:16 PM »
bugger any ideas where i could pick one up from?what sort of cost are they?thx for the swift reply bud. :wave:
Re: 3rd gear
« Reply #3 on: August 02, 2009, 05:56:49 PM »
Hi Rudi , I had a Bis from new & after two & a half years & a normal mileage I went out for a drive one morning & 3rd gear just dissapeared with no warning at all. I had to keep driving the car but the gearbox went into a steady decline. I got a good offer on a trade in but had to wait for the new car. The gearbox got almost impossible to the extent that the day before the trade in I rang the salesman & told him it was a bit dodgey. He said that as long as I could drive it there then the deal was still on. I had to force & hold the car in either 1st or 4th to get forward motion but half way there I lost that  :oops:
Ended up reversing the car the last one & a half miles & did the deal  ;D
Anyway that does not help you & like the Bis 13 man says , assuming your linkage is OK & properly adjusted , you are looking at a rebuild or a replacement. If you are reasonably handy & have a socket set then the Haynes manual can talk you through a rebuild. Some body wiser than me may corect me but I believe the Bis gearbox ratios are the same as the Air cooled cars , the Diff & bell housing are different . As my son kept on breaking 126 gearboxes (often not his fault as I found out) I have stripped down a few so I have  box of internals up in my shed which have helped out a number of people. If your 1st & reverse are in good order then it may be worth a rebuild if you can't get a replacement box & if you find a broken bit I may have one sitting in my shed,
good luck  [-/
Re: 3rd gear
« Reply #4 on: August 02, 2009, 09:32:56 PM »
i dont know if third is any different in the bis box but i know fourth is for sure have a look around as theres plenty of spare boxes around and there must be some down your way.
rudi van disarzio
Re: 3rd gear
« Reply #5 on: August 03, 2009, 07:29:04 PM »
thx rusty,reversing one and a half miles sounds cool,will let you know the outcome and if i need bits thanks again. [-/ rudi.
Re: 3rd gear
« Reply #6 on: August 03, 2009, 10:48:26 PM »
theres a box and aircooled engine going down in bristol thats nearer to you than most bits will be have a look in the thread. titled " advice please"
Re: 3rd gear
« Reply #7 on: August 03, 2009, 10:51:39 PM »
I have some BIS box bits, in Southampton if that helps, might be a bit closer :oops:
