Author Topic: 126 el  (Read 2802 times)
500mike
126 el
« on: August 01, 2009, 02:26:18 PM »
Hi I have just aquired a 126 el engine that I want to do up.
there is no distributor, just a pickup on the oil filter rim for crank position.
I have no coil or control unit.
can anyone help me with these parts or info?
thanks
Mike
Re: 126 el
« Reply #1 on: August 01, 2009, 02:48:28 PM »
Hi Mike , not sure what you mean by a 126 el engine , are you talking air cooled or a Bis water cooled engine  ??? [-/
500mike
Re: 126 el
« Reply #2 on: August 01, 2009, 03:10:27 PM »
 126 el is aircooled late model engine with an alternator. cica 1997.
 Last aircooled model before going over to the bis model, I think
Has no distributor, no hole for it, just the pickup off the crank, so must have been an electronic ignition upgrade of some kind.
thanks
Mike
Re: 126 el
« Reply #3 on: August 01, 2009, 03:35:44 PM »
The last of the air cooled cars sold in the UK in 1987 when the Bis took over until 1992. I think I have heard of the set up you have but never seen it in the flesh. Some of the Polish guys that come on the forum will probably know more about it  [-/
Re: 126 el
« Reply #4 on: August 01, 2009, 03:49:04 PM »
i think they never made it to our soil so its a polish friend you need have a word with jan he certainly will be able to help you.
Jan-in-UK
Re: 126 el
« Reply #5 on: August 01, 2009, 06:17:37 PM »
If it is aircooled so it will be certainly engine from EL or ELX verison. It is the very last version of fiat 126 wircooled engine, the same you can find in all of them made between 1994 to 22.09.2000 when factory stopped....
www.fsoclub.co.uk
500mike
Re: 126 el
« Reply #6 on: August 01, 2009, 07:24:29 PM »
Well that would all make sense as the guy I bought it from was Polish!!
If it is of interest I can post a picture of the engine
Jan, can you find any info about the missing bits for me?
I guess the coil was a 2 pole device (sorry for the pun) and was running wasted spark. I guess the coil is not too difficult as I can use one from a motorbike, the electronics might be a different matter.
thanks,
Mike
Re: 126 el
« Reply #7 on: August 01, 2009, 08:03:26 PM »
so theres no distributor on this model? i didnt realise they went high tec towards the end with a electronic engine management!!
500mike
Re: 126 el
« Reply #8 on: August 01, 2009, 08:45:44 PM »
Ok just to prove its not 1st April I have taken some pictures of the relavent bits of the engine, can anyone steer me through posting up some pictures on site?
on the rear of the oil filter are 2 lumps for the sensor to detect as it goes round. My best guess is that one is the static 10 deg setting and the other maybe max advance. any other ideas? perhaps it will be clearer with the pictures posted.
Mike
phreak97
  • Niki!
Re: 126 el
« Reply #9 on: August 09, 2009, 01:58:25 AM »
register with www.photobucket.com
works great for me
phreak97
