Author Topic: General help/info for a BIS owner  (Read 2285 times)
Alex
« on: July 27, 2009, 09:29:58 AM »
i was hoping some of you kind people could offer a new bis owner some advice!
after spending the weekend tinkering with the car a few more problems have arisen, i have mangaed to sort the master cylinder, but there is now an issue with the engine overheating! i have removed the thermostat, and boiled it on the hob and it has completely seized up! does anyone know where ican source a new one? also one of the bolts that hold the thermostat in place sheered off when trying to remove it, are these bolts available to buy anywhere?
all of the hoses and lines are looking very shabby and i would like to replace them as well, are these also available?
finally the air filter is ruined, are these available for a general motor factors?
thank you for any help you can offer,  i will be posting pictures of my progress as well
Re: General help/info for a BIS owner
« Reply #1 on: July 27, 2009, 11:37:53 AM »
Most parts are available for the BIS on a website calle Axel Gerstl.
Carriage can be scarey so get a big order or all the bits you need at once.
E bay is another option.
take the thermostat, and chuck it in the bin, and then put it together again without it.
It takes a little longer to warm-up but it will blow it's head gasket if it overheats.
I ran mine for years without a thermostat with no problems. :oops:
« Reply #2 on: July 27, 2009, 01:54:00 PM »
 :) Ditto what Darrell says about the thermostat. If it is just a plain bolt that has sheared then these are easily available , if it is a stud then it may be a little more difficult. Also can you get the broken bits out OK as many a good alluminium casting has been wrecked by some well intentioned DIY work ?
Alex
« Reply #3 on: July 27, 2009, 02:59:02 PM »
i'm unsure of what you mean by discarding the thermostat?
if the thermostat is not engaged then how does the engine regulate the coolant through the radiator? the bolt has a thread halfway up its shank then its blank.
also why do the replacement thrmostats look nothing like the one from my Bis?
are there different types for the Bis?
cheers
« Reply #4 on: July 27, 2009, 05:49:28 PM »
Throw the thermostat away, and don't put another one in ever, is what I'm saying.
The flow of the coolant through the radiator will be constant but that doesnt matter as a BIS heats up pretty quick.
These cars have a history of blowing head gaskets because the thermostat didn't open on time, or it got stuck, we've heard the stories all too often on here.
Better the car takes a little longer to warm up and you spend less time covered in oil cursing  [-/
There is a 'conversion' apparently for sale for some hundreds of pounds but never tried one and frankly why spend where you don't have to.
The conversion apparently takes the thermostat and puts it closer to the head (source of heat, and source of headaches) :oops:
Maddog
« Reply #5 on: July 27, 2009, 07:42:38 PM »
if you can give a better description or post a pic what bolt is sheared and the location, then you'll get the best advice on how to fix it,
axel gersts postage has always been really cheap for stuff I've bought, but email him first to check if he's got the parts you want in stock, if he doesn't it can take ages to get them.
giving the coolant system a good flush before refitting would be a wise move too.
Alex
« Reply #6 on: July 27, 2009, 09:19:36 PM »
Hi the thermostat advice has been great,
i will remove it from the car, if anyone has a picture of their car without the thermosat i would appreciate that,
on a different note, anyone tried to get hold the clips for the front headlights, so they can be adjusted?
and also finally i am going to replace the hoses, i realise the carburettor to air filter hose is a specialist size, but i am going to replace the other with standard hoses rather than pay a small fortune for the ones from online sellers, has anyone else done this?
cheers again for the advice so far
« Reply #7 on: July 27, 2009, 10:54:01 PM »
hi Alex,
congrats on your 126!
yes Darrell is right, i would say remove the thermostat from the housing, i remember removing my thermostat for the first time and it was just full up with gunk from limescale and corrosion build up.
heres one on ebay
 http://cgi.ebay.co.uk/Thermostat-Gasket-126-Bis_W0QQitemZ380129537024QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item58817c6c00&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1683|293%3A1|294%3A50
its only in cold weather it will take longer to warm up, your engine will last longer leaving that thermostat out.
Major thing to remember is to bleed the cooling system straight away, airlocks build up really easily when you fill it up with water, the header tank usually gurgles with air when you fill it up! My head gasket went again straight after i filled it up with water. The litte stop cock comes off a small pipe at the front of the the car in the luggage compartment by the heater matrix. Make sure you fill it up with anti corrosion inhibitor,
Hope this info helps
Regards
Alex
« Reply #8 on: July 28, 2009, 11:40:35 AM »
thanks for the advice, i have ordered the thermostat thing off ebay and will fit it this weekend! i have also seen the step by step guide for cleaning the oil filter! is this recommended as well?
regards
Alex
« Reply #9 on: July 28, 2009, 12:04:00 PM »
Yeah do the filter and change the oil. Change the fuel filter, and I'd do plugs points and condenser too but then be sure you know how to set the points up first.
I'd also run the engine till warm to check the fan comes-on and also the fuel pump is working properly.
9/10 times there is nothing wrong with the pump, there is a rod which pushes the pump up and down runs directly off the cam. This rod wears, as the crancase expands it isnt long enough to operate the pump but running it will tell, no need to take it out yet.
If it is a problem, let it cool down, dont panic [-/
Other than that baby Fiats all have their own personalities and you'll probably come-up with a unique problem, relevant only to your car :P
