Author Topic: Setting idle speed and mixture..  (Read 1927 times)
« on: July 20, 2009, 04:16:26 PM »
Ok, i having some problems with my car, its really smokey, running unsteadily and my sparks have to be cleaned every so often (dry and black). i am told that this is becouse the mixture is too rich. how do you set up the mixture on a bis, i have 2 screws on the front of the carb (its not identical to the original but shouldnt be too different) which do something but not really sure what :P any help would be greatly appreciated...  [-/
Re: Setting idle speed and mixture..
« Reply #1 on: July 20, 2009, 04:21:32 PM »
For it to be running that rich I'd suspect either flooding of the carb or as you said you carb is close to original, perhaps the jets are too big.
My air mixture screw just adjusts the idle mixture.
Check the float level first.
On bikes we use a piece of clear hose pushed-on to the drain, one holds the clear hose up to the side of the carb and it gives the level.
On my Air cooled I did as the manual said :P
