Author Topic: which standard fiat parts fit?  (Read 2380 times)
mic
« on: July 13, 2009, 08:17:31 PM »
thought it might be worth having a list of standard bits off pandas, cinqs and any other old fiat that could be used as an upgrade for a 126.
i wouldt know where to start  :oops2:
Re: which standard fiat parts fit?
« Reply #1 on: July 13, 2009, 08:41:15 PM »
I suggest you read a bit of the forum or use search facility. ;D
mic
« Reply #2 on: July 14, 2009, 09:58:35 AM »
thats ok if you want something in particular i.e. brake conversion stuff but i mean a generic list someone could print off and pocket so they know what to look for in general when next at the scrap yard  :)
« Reply #3 on: July 14, 2009, 10:25:05 AM »
Ok, heres the link, the cinq is pretty much the only car with straight swap bits for the 126...
(although i must say the sunvisors from the cinq do not fit as stated in the topic, i got them and the holes are the same but its larger and cannot open fully cos the r.v. mirror is in the way... - got it, tried it, scrapped it...)
http://club126uk.co.uk/smf/index.php?topic=2813.0
« Reply #4 on: July 14, 2009, 08:55:32 PM »
Oh what a suprise someone used the search and found the link for you.
mic
« Reply #5 on: July 14, 2009, 10:10:56 PM »
I'm sure that's condemed me to hell.
phreak97
  • Niki!
« Reply #6 on: August 10, 2009, 02:56:55 PM »
I'm confident there are other fiats which have parts that are interchangeable.. I've got a fiat 850 sport and a fiat topolino, and I've gotta say the seat runners look bloody close in all of them, I daresay a bambino would be the same too. the handbrake lever in my 850 looks the same too but it's chrome, cant guarantee the workings underneath are the same though. there are a few rear engine fiats that use the same type of flexible joints on the drive shafts too,
also I was given some disc brakes that I was told will fit a niki with only one new hole drilled on each side, I think they may be from a fiat 850.
lets not go past that the whole motor from a 500 or 126 can be swapped, and so that includes such cars as the autobianchi bianchina etc however rare they are.. they also share the same suspension mounts etc, wishbones are interchangeable.
I find often if I cant find a part I can do a search for it in google and some online store is likely to come up which will usually list a few of the cars that the part fits, then you can go back to ebay or wherever and search under the other cars aswel.
phreak97
