Author Topic: Help Needed PLEASE!  (Read 1578 times)
custardboy
Help Needed PLEASE!
« on: July 10, 2009, 03:36:01 PM »
I have been trying to resolve a bad oil leak on my air cooled for several weeks now.  Oil was coming out of the thermostat flap and burning on the exhaust producing a lot of oil smoke.  I rebuilt the engine over christmas with all new seals even so I have just done the cylinder head gasket and pushrod tubes seals again.  This time I have removed the thermostat trunking and can see the well at the bottom of the push rod tubes is filling with oil, also the fins on no. 1 barrell are very wet with oil wheras no. 2 barrell is bone dry.
I am at a loss as to where the oil is coming from and apart from this problem the engine runs very well and a compression check reads 150 psi on both cylinders.
If the paper seals between barrells and crankcase had gone could this be cause of oil leak?  Is there anywhere else it might be coming from?
Any advice appreciated as I am beginning to loose my enthusiasm for my 126 :(
Re: Help Needed PLEASE!
« Reply #1 on: July 11, 2009, 04:13:53 PM »
its got to be coming from the seals between the barrels did you use any gasket sealant when you refitted them as this does make them work better than just sandwiching them.
custardboy
« Reply #2 on: July 12, 2009, 08:14:13 AM »
No I didn't use any gasket sealant and I did wonder whether I should.  I know some can and some can't as have done paper seals to bottom of cylinder linerss on a Renault 5 turbo and that wouldn't work if you any kind of gasket compound with the paper seals.
Thanks for the advice I just needed someone to confirm my theory to push me on, I've had the head off twice this week with engine in the car, very fiddly, I was trying everything I could think of without taking engine out, again!
I'll take the engine out today and do those seals!
« Reply #3 on: July 12, 2009, 12:32:59 PM »
its just a pain as they are so weak can you make your own out of thicker gasket paper? you can buy copper versions in italy i think nani or 500mania sell them. its the fact that you have to drop the sump again to refit the pistons its a simple job but ends up so long winded! well good luck and hope it gets sorted.
