Author Topic: Please help an extreme novice ...  (Read 1834 times)
Jayne126:D
« on: July 08, 2009, 08:52:22 PM »
Hi, Im having problems with my bis and was hoping to get some advice. Use small words though, im new to all of this  ;)
I think im having two separate problems at the same time so ill start with what i think may be overfueling?
For a couple of weeks, whenever i start the engine it has juddered and jumped around, ive been having to rev the engine a lot to get the car to settle. Once i have bounced up the road it starts to act normally and i can drive with no problems. Ive been using the choke as i normally do so i don't think that is the problem. It started after i put premium unleaded in - some-one told me that its a good thing to use premium fuel once in a while. The bis really didn't like it though!! And has been behaving like this ever since. Ive been putting the usual fuel in instead trying to water it down but nothing is changing. Do i need to alter the valve that changes the air/fuel mixture? And if so how should i go about it? Where is it? And is getting the balance right a trial and error thing?
Onto a more immediate problem ... I could live with the juddering .. but now its not starting at all!  :(
When i turn the key the engine makes no noise what so ever. All i can hear is a clicking noise?? As if its trying to spark but not catching????
My battery light has come on so we tried jumpstarting it and charging it for a bit and it worked for a while. However the next morning it was a non-starter again. Would you recommend replacing the battery?
Does anyone think the two problems are related?
I should probably take him to a garage but i really want to learn and at least try for myself first so any advice is greatly recieved.
P.S Ive had my Bis since March now and im loving it! Get a great reaction everywhere i go. Have given him a comic book print parcel shelf and an 8 ball gear knob too! No other car could pull that off   ;D
Jan-in-UK
Re: Please help an extreme novice ...
« Reply #1 on: July 08, 2009, 09:10:19 PM »
If anybody would ask me it could be only battery. Sometimes when battery is completly worn it has not enough power. First to supply spark and keep engine running and second - to start the car at all. I had aexactly the same problem with my VW bus in the past and to be honest I did try everything else before battery  :-X and everything was ok. After I put brnad new battery All was ok strait away  [-/
Think whatever bothers your fiat you could do with new battery. I am not big specialist (I am sure couple of them here will be much more helpfull) 8)
Good luck and keep rollin'
www.fsoclub.co.uk
« Reply #2 on: July 08, 2009, 09:53:49 PM »
deffo battery problem but check to see if there are any perished or loose wires leading into the alternator there is a thin one that tends to come off. as for the judder it could be all sorts do you know how to static time the car? another area that can cause juddering is when the brakes bind on. another thing is you say you need to rev the car lots to get it to settle when you rev the engine does it increase the revs dramatically or sound like its laboured and doesnt rev very well? if so it could mean a fuelling problem normally attributed to the fuel pump giving up.
« Last Edit: July 08, 2009, 09:59:54 PM by bis13 »
defender90
« Reply #3 on: July 08, 2009, 09:58:44 PM »
You need to check that it's charging first, you may have a perfectly good battery that is going flat because it isn't charging. If you'r red ignition light is on whilst your engine is running over tick over then it isn't charging and if you put a brand new battery on whilst not charging it too will still go flat. If it isn't charging first thing to check is the alternator belt, is it still on and if so is it tight enough? Then check all the wires to the alternator and battery. If wires all ok and the belt is on / tight enough and the red light is still staying on whilst running then it is most likely the alternator that needs replacing or repairing(new brush box). Also if the battery isn't a sealed type check the electrolight levels of the battery cells by removing all 6 tops and looking in.(correct level is liquid just covering the tops of all the cells). Once you are happy it is charging and battery levels OK if the battery is still loosing it's charge then do replace it.
Good luck
Kev
Kevan
Radcliffe
Gt.Manchester
Citroen BX TDG (soon to go)
Citroen BX TZD
Land Rover 110 Station Wagon
« Reply #4 on: July 09, 2009, 12:40:24 AM »
yes Kev gave some good advice there,
sounds very much like the battery not holding a charge they usually last for a few years, get down to halfords, take your old battery to measure up the dimensions and battery type and keep the receipt for the 3 year warranty.
if you dont use the car regularly then leave the batt disconected or buy a trickle charge to keep it toped up whcih will preserve the life of the batter.
Also to begin with it sounded like a fuel prob to me, sounds like it could be a blocked jet in the carburetta or the carburetta float leaking or not adjusted properly causing it to run poorly.
Good luck. let us know how you get on
regards
« Last Edit: July 09, 2009, 12:53:32 AM by Chris Lakin »
« Reply #5 on: July 09, 2009, 07:41:25 AM »
 :) Hi Jayne , I thought I would have my three pence worth & keep it simple. Before you rush out & buy a new battery you need to check the condition of & how tight the fan belt is . If it is too worn and /or too loose then it is possible that the engine, via the big pulley , will drive the alternator (the round thing about the size of a small loaf of bread with a pulley on the front) just enough to produce enough electricity to make the ignition light (red one) go out but not enough electricity to recharge the battery. This can happen especialy with alternators & the driver thinks that all is well as the red light goes out when driving but in actual fact the battery is getting flatter all the time. It is worth getting a new fan belt anyway as a spare & you would be able to compare widths for signs of wear. Not sure about the recomended tension for a Bis but on the aircooled cars firm pressure with your thumb at the centre of the belt should give a deflection of about half an inch.
When you turn the key to start the car and all you hear is a click, assuming the starter motor is good (sounds like your's is as it works with a jump start  [-/ ) without getting to tech . On the starter motor there is a thing called a solenoid which when you turn the key it engages (moves some bits) the motor with the engine so it can turn the engine over & start it. If the battery is low then there is just enough power to engage the solenoid , that is the click you hear , but not enough to turn over & start the car.
If you can get to see inside the battery possibly by a number (6) screw in plugs or possibly a couple of plastic covers that lever/lift up. Be carefull as the battery is full of acid or should be. Idealy you should see just below the surface of the acid (which looks just like water) the top of some thin grey lead plates ( which look a bit like a bunch of grey After Eight Mints standing on end) . If the acid is not showing just above those plates then you need to get some battery top up water from a garage or shop. Not Evian or Perrier but about the same price & will probably last you forever. Top up battery and try running again. If still no good you will need to go on from there.
Just one thought about the way the engine runs, has the air filter ever been changed . Easy test is just take it out & see if the engine runs better , good luck  :D
