Author Topic: The 795ccs Fiat 126 Alquati Italtune Engine.  (Read 8884 times)
« on: July 06, 2009, 03:08:32 PM »
OK I have been running small Fiats on & off for over 30 years & mainly 126s & for those of you who have not been through the DARK YEARS when "enthusiasts" wanted these for £50 or less & the thought of spending a pound on the annual running costs was a painfull concept. Many people appreciated the car for what it was and treated it accordingly hence some of the little gems that turn up from time to time and although they cherished them , generaly being the less well off , spent love rather than lots of money on them.
So I spoke to the guy this morning that I got this engine off as I had a list of questions . First one was "Did you have this engine in a 500 or a 126?" - "It was a 126" - "Did you initiate the work?" - "Yes" - "Do you have any records on the engine?" - "I came across the bill for the initial work on the engine about a year ago, I am sure I still have it , I will look it out , it was about £1000 I believe" .
We discussed a couple of other things which I will come back to later but the nice thing was "Do you have any idea of how many miles the engine has done?" - "2 to 3,000 miles I would say"
Pretty much just run in then  :) :) :)
If we ever get a 126 Hall of Fame then this guy has got to be right up there but sadly the car was scrapped a quarter of a century ago. More to come  [-/
hudsonhenry
    • http://www.retro500.com
Re: The 795ccs Fiat 126 Alquati Italtune Engine.
« Reply #1 on: July 06, 2009, 04:56:10 PM »
Sounds like a great find, when are you going to post some pics up?
Nigel
« Reply #2 on: July 07, 2009, 06:17:14 AM »
Hi Nigel & All , Good to hear from you as I have been following your threads on the Forums & I know you have an "interesting" car. There have been quite a number of requests for pics of the engine but I seem rubbish at trying to post them but that may change when I get my new (to me) computer next month. But as I was saying to Mick last eve that apart from the big fat alloy sump and the Dellorto FZD 32 Carb on top it looks like any 2 cylinder Fiat aircooled engine. It is mainly what is on the inside that counts & I hope to keep a good photographic record which I will be happy to share. As I have two engines & three gearboxes in bits at the moment with a number of other projects going on I may not start on the rebirth of 795 proper until next year. The other problem is that apart from disc brakes I am running a standard , beaten up Fiat 500L which I have only just got back to running on the original 125 x 12 tyres. Might have to do a bit of beefing up in some areas if I am going to trial the engine in my car  [-/
« Reply #3 on: July 28, 2009, 11:35:23 AM »
I have done a little bit of work on the head & got it to the condition that I am happy to run with but to recommission the engine I am thinking of making or having made solid copper sheet head gaskets, probably about 1 to 1.5 mms . Any thoughts or experiences on this  ???
I was going to bid on the 126 Workshop Manual that went on eBay for 99p last night but my BT Total (S**T) Broadband went down again. Anybody else having problems with their normaly reliable service ?
I hoped that the manual might have had an engineering drawing of a head gasket in there which would help if I have to get them made . I can hack one out myself but I spoke to the guys that do the laser cutting for the disc brake adaptor plates & they can get copper sheet cut by a computer controlled water jet process  [-/
« Reply #4 on: July 28, 2009, 12:30:24 PM »
Rusty mi old mucker! There's an aircooled/bis manual and other microfish in the subscriber section [-/
« Reply #5 on: July 28, 2009, 07:01:27 PM »
I could always copy my full manual and pop a copy in the post.
« Reply #6 on: July 29, 2009, 03:10:59 PM »
 :) Hi Dadwij , thank you for that offer but the thought of all that copying & the postage is all a bit much . All I wanted at this stage is a drawing of the head gasket so I can get it right. But thinking on it there is no real reason why the head gasket needs to be made in one piece so I realised that it could be made in two parts, one for each cylinder. Although I want the gasket for the 85 mms diameter bore on the 795ccs engine I could also investigate higher compression gaskets for the 652ccs engine if anyone is interested  ;D
« Reply #7 on: December 07, 2009, 05:18:47 PM »
Bloody awful day for a drive but I took the morning out to pay a visit to the guy I got the engine from as he had found some of the original receipts & instrumentation. So I now have three sheets of A4 paper & a nice little triple gauge intrument pod fitted with matching Veglia Borletti gauges. An oil pressure gauge , oil temperature gauge and a clock. Cost me a few bob but they are part of the original package and are in very good condition. Sadly the guy could not locate the matching rev counter but I have seen the pod for that & hopes are high.
Had a chat with the guy over a coffee & asked him why he spent so much money on a Fiat 126 , as I would guess that he must have spent well over £2,000 in the mid 80's . He said that he always liked to run the small Fiats and bearing in mind he was a prominant test pilot and part time racing driver he thought it would be a bit of fun. He did also say that he had to fit a front spoiler to keep the car on the road when he got over 90 mph.
He also told me that he prepared the car as a fast road car rather than full race which is also encouraging.
Top line of the first invoice reads "Stage 1 Cyinder Head" , second line "Big Bore Kit" & so on ....................  :oops:
hudsonhenry
« Reply #8 on: December 07, 2009, 06:09:41 PM »
Rusty
Sounds like a great result, whats the timetable for getting the engine running and fitted and is it destined for your 500 or126? Is the instrument pod one for a 500 or for a 126? I have only ever seen them for 500's so if its 126 specific it must be very rare indeed.
Good luck with finding the rev counter
Nigel
« Reply #9 on: December 08, 2009, 08:58:40 AM »
In my distant memory I seem to remember you can have the block recessed with a set of wire rings instead of a head gasket -in the case of an engine like this would that be a suitable solution ?
(merely asking in debate not butting in as a know it all....)
« Reply #10 on: December 08, 2009, 03:46:35 PM »
I was kind of hoping to get the engine up & running sometime next summer and thought that the Kop Hill climb event at Princess Risborough could be a good target date. The instrument pod has no back to it soit may just be designed for another Italian car as part of the dash. I did find a similar clock on the net & that was described as being for a Ferrari. Also not sure what cars would have a separate oil pressure gauge with low warning light & an oil temperature gauge.
I did not mention that I picked up a Panda 30 head a short time back & I mentioned it in my chat with the Sqaudron Leader retired. He got quite excited about it because they just did not exist when he had the engine done. I went on to say that I thought that I might install the engine in a de-tuned form, low compression gasket and a standard carb. He nearly put me up on a charge and pretty much said that it was my duty to get the best kit possible on the engine  :oops:
Probably mentioned it before but he has just turned 70 years young , drives a Cinquecento with a tuned 1.6 Punto Sporting DOHC engine that he fitted himself & was just in the process of fitting Alfa vented disc brakes to the front of his other Cinquecento but that has only got a tuned single OHC unit fitted by him.
So chocks away then  </8
Stuey those things are called piston rings & generaly get fitted lower down  </4 </4 </4 </4
« Reply #11 on: December 08, 2009, 04:16:39 PM »
Lol i know what a piston ring is... but thanks for the clarification  ;D I am serious though I cant find the info at the mo I beleve you can have a small recess cut in the top of your bore then its wired with copper?
« Reply #12 on: December 08, 2009, 05:30:02 PM »
Hey Stuey , remember I met you at retro rides & I know what a young buck of a hippie you are with all of that hair so I reckon it is all of that sex , drugs and rock & roll that have taken there toll on your memory  ::)  ::)
As for small recesses I have got one right across the top of my head where that guys double garage door came down on places where I once used to have hair  :oops:
fightingtorque
« Reply #13 on: January 13, 2010, 08:03:58 PM »
Stuey, the rings you are talking about are called 'wills rings'.  I have never seen one, but the 998cc imp people used them, it is a metal ring made from fine round tube section, and contains some kind of powder that vaporises with heat, trying to make the ring expand and therefore creating an excellent seal.  I don't know if they still exist though, haven't heard of their use recently.
« Reply #14 on: June 21, 2010, 06:19:37 PM »
Had to move the engine today , still no real time to get stuck into it or to fit my newly worked head on my runner which is annoying. Whilst I was at it I removed the last two bits of tin ware which were the front & back sections of the fan housing. Two observations, 1st the front section had a piece cut out right at the base where the cooling air would have been directed to the sump and there was a hose support for something like a 1" hose bolted to the base of the casing , any ideas  ???
Also as I suspected the cooling fan is made of black high density plastic moulded onto a steel structure . I have only seen the steel ones or the alloy cast ones before so is this a standard fan  ???
