For Sale & Wanted
Wanted:
Air-cooled 650 head
Pages: [
Topic: Air-cooled 650 head (Read 4728 times)
Air-cooled 650 head
on:
July 06, 2009, 09:45:44 AM »
Hi, I'm after a 650 head with/without rocking gear and rocker cover. Mine is hanging-in there but feel it's life span is going to be limited
Not the only African in the village
Subscriber VIP+
Re: Air-cooled 650 head
Reply #1 on:
July 06, 2009, 09:51:34 AM »
The head has to be in very poor condition for it not to be fixable. I am literally in the middle of just fixing a 500 head and an interesting modified & ported 126 head . Typing with dirty fingers
Reply #2 on:
July 06, 2009, 09:58:55 AM »
It has strripped the threads out of the studs that hold the rocker shaft on.
Trouble is she's now our only car so cannot afford to muck-about too much with it.
Subscriber VIP+
Reply #3 on:
July 06, 2009, 10:05:25 AM »
Easy helicoil job , One of the first things I invested in when I got my latest car was M6 , M8 & M10 & Spark plug (M14) sets, shame you do not live closer. You need M8s for those studs [-/
Reply #4 on:
July 06, 2009, 10:09:14 AM »
I fear I may have gone backwards, I drilled the rocer shaft bits to 10.2mm then drilled and tapped the head to M10, it now has M10 studs..
Subscriber VIP+
Reply #5 on:
July 06, 2009, 11:21:54 AM »
Oh you boys , what are you like ? Anyway if the rest of the head is OK then you should be OK for a while. Also if you have tapped the head with the finer M10 x 1.25 thread then you can still fit M8 inserts straight in. I guess that you have also drilled your rocker box cover as well.
Andi
Reply #6 on:
July 06, 2009, 12:08:46 PM »
M8 Helicoil is drilled 8,3mm. With M10x1,5 in the head Darrell can't use M8 inserts.
Last Edit: July 06, 2009, 12:11:31 PM by Andi
Subscriber VIP+
Reply #7 on:
July 06, 2009, 01:06:07 PM »
Hi Andi , notice the word "finer" in my post & hence the "M10 x 1.25" . Come on you guys were bought up on Metric , I had to convert from feet , inches , rods , poles & perches
Reply #8 on:
July 06, 2009, 01:19:42 PM »
Guilty as charged
Andi
Reply #9 on:
July 06, 2009, 02:36:03 PM »
So far you are right. The rise would be the same as the M8. But: I don't think he used a 1.25 , as even on the metric continent of bliss you have to make a daily travel to find a 10x1,25... [-/
Reply #10 on:
July 06, 2009, 05:36:01 PM »
why not fit helicoil into helicoil to close up the hole and loctite it? it may sound a bit iffy but is it worth a try?
Andi
Reply #11 on:
July 06, 2009, 07:20:04 PM »
Definitly not! Helicoil is only a wire, an in-in-solution wouldn't do it anyway. There's another repairkit from Würth, called "time-sert". This has the same thread as Helicoil, but is a more or less solid tube instead of a wire. Ok, my english gets weak...Now, watch this:
http://www.wuerth.de/de/produkte/auto/time-sert.html
With this Darrell could have saved his 10x1,5 to M8, because it has another system of fixing. But the set is very expensive, and you have to work exactly.
nrg19uk
Reply #12 on:
July 06, 2009, 08:46:38 PM »
http://cgi.ebay.co.uk/Top-Quality-TIME-SERT-Metric-Course-Master-Set-NEW_W0QQitemZ310153617949QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item483698a21d&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1683%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Neil gargaro
Subscriber VIP+
Reply #13 on:
July 06, 2009, 09:10:20 PM »
[-/Well spotted on that one & that is a good bit of kit as whilst a well fitted helicoil is good for most applications the top rally / racing engineers use what I have always known as Keenserts , I guess those are a crib but if they are half as good then it is a good buy
Reply #14 on:
July 07, 2009, 08:21:55 PM »
thats bloody well cheap its around twenty odd plus quid for just a helicoil set with no drill bit. i only said helicoil in helicoil as a sort of question as i have done it in the past to get my old production line back up and running merely a stop gap so to speak..i like the look of these sleeves indeed.
Pages: [
For Sale & Wanted
Wanted:
Air-cooled 650 head
