Author Topic: keeping pulley static.  (Read 3948 times)
« on: July 05, 2009, 06:01:26 PM »
i needed to pull out my cam to see what damage had been done but wished to keep the engine in situ so found it difficult to keep the pulley static in order to remove the main crankshaft nut , i ended up doing this and worked very well and made torqueing up again so much easier .
Re: keeping pulley static.
« Reply #1 on: July 05, 2009, 08:23:52 PM »
wait, i dont know if im missing something, but wouldnt putting the car into gear stop the engine from spinning? or am i off course with this one? </6
« Reply #2 on: July 05, 2009, 09:15:16 PM »
your in the wrong hemisphere completely my friend i tried that and still couldnt get it undone.
Andi
« Reply #3 on: July 05, 2009, 09:22:53 PM »
what's the english word for "Schlagschrauber" ???
« Reply #4 on: July 05, 2009, 09:25:13 PM »
i dont know but it sounds rude!! :D
just looked it up andi its an impact wrench!!
would have preffered buxom wench mind....
« Last Edit: July 05, 2009, 09:34:17 PM by bis13 »
« Reply #5 on: July 05, 2009, 09:30:54 PM »
 :o I had to undo 2 of those nuts last week as I am rebuilding one engine from the best bits , believe me they are a real mother to deal with.
Andi
« Reply #7 on: July 05, 2009, 09:46:17 PM »
  :oops: Forgive me , when you said " household schlag schrauber" I thought that I was going to have to stand up for women's rights but then I looked at the picture & I do not think you would have a chance with that pop gun , more likely to break a wrist  :cry:
« Reply #8 on: July 05, 2009, 10:21:45 PM »
http://www.household-discounter.de/media/images/schlagschrauber-2.jpg
is that the compressed air powered drill thingy :P if it is i have one of those but it cant undo the wheel bolts its so weak  ::)
so i take it replacing the main bearing on this side of the engine isnt going to be as easy as i thought it would be ( i was gonna do this eventually  :oops: )
« Reply #9 on: July 05, 2009, 10:43:31 PM »
oh its easy but the nut on the crank is torqued to about 110 kgm thats the hard part after that its easy stuff i just found that in the car the pulley must be braced .
« Reply #10 on: July 05, 2009, 10:47:52 PM »
oh, cool, i have a BIG brother, ill let him figure that part out  :D
Andi
« Reply #11 on: July 05, 2009, 11:18:32 PM »
The picture was only to find out the english word. My "Schlagschrauber" does the crank-nut easily, it' not a toy like the one on the picture...
(Impact wrench?)
« Last Edit: July 05, 2009, 11:20:08 PM by Andi »
« Reply #12 on: July 06, 2009, 09:43:19 AM »
I put a piece of bar accross the flywheel (after removing the little cover) and clamped it with two G clamps. Have to admit my G clamps seemed to be just right, not all would fit I think.
Andi
« Reply #13 on: July 06, 2009, 11:49:57 AM »
Another way is to remove the oilpan and to stick a piece of wood between crank and housing.
« Reply #14 on: July 06, 2009, 01:02:11 PM »
Mick you should make copies of your tools and sell them to the rest of us as taking the sump off or my clamping method is a pain in the proverbial!
