Author Topic: Dipped beam not working  (Read 4778 times)
markie
« on: July 05, 2009, 02:05:28 PM »
Hi guys.
Any idea on this one? the bulbs are new etc, full beam works, side lights work and I've looked at th electrical schematic noting Grey/Black and the Grey wires are the plus feed but no juice runs through them  :(
as you all know when you pull the light switch stick towards you this flashes your lights on dipped beam, this still works,  I'm confused.com  :cry:  Help
Re: Dipped beam not working
« Reply #1 on: July 05, 2009, 02:24:08 PM »
If you use higher than the original power bulbs without fitting a relay then it melts the column switch unit. Hope it is not that & that it is just a simple wiring problem  [-/
markie
« Reply #2 on: July 05, 2009, 03:14:25 PM »
I think you are right, I've just come in and sat down after having fried £45 worth of wasted spark coil through leaving the ignition on, a nice smell of melted plastic and white smoke from the engine compartment.  :cry:
defender90
« Reply #3 on: July 08, 2009, 10:18:17 PM »
Pulling your stalk to flash your headlights is normally full beam not dipped , are 126's different?
Kevan
Radcliffe
Gt.Manchester
Citroen BX TDG (soon to go)
Citroen BX TZD
Land Rover 110 Station Wagon
« Reply #4 on: July 08, 2009, 11:09:20 PM »
thats what he said the lights will flash but he has no dipped beam.
defender90
« Reply #5 on: July 08, 2009, 11:32:39 PM »
No he didn't he said
 ''as you all know when you pull the light switch stick towards you this flashes your lights on dipped beam''
  flashes the lights on dipped beam not full beam???
Kevan
Radcliffe
Gt.Manchester
Citroen BX TZD
« Reply #6 on: July 08, 2009, 11:49:54 PM »
yes, when you pull the stick it flashes the high beams, not dipped, (when the low beams are on, and you pull the stick, both hi and lo beams are on, when you pull the stick down the hi turns on and lo turns off...) im sure its just a bad contact somewhere...
markie
« Reply #7 on: July 09, 2009, 01:46:07 AM »
 I so Love this! Back in 1988 it took me 2 weeks to sus out that if you flash yr lights on any other car than a 126 then it's high beam but hey 2day I got sacked so I'm gonna take time out 2 wire my lights back 2 front so I can flash on high beam!  8)  Cheers guys 4 bringing me back 2 reality  :)  (no disrespect)
« Reply #8 on: July 09, 2009, 08:06:29 AM »
jesus why are you so pedantic? its clear he meant it switches from no dip to full beam when he uses the bloody stalk .
« Reply #9 on: July 09, 2009, 08:30:42 AM »
 ::) Interesting times then  ??? Did you get your coil sorted OK  ???
Seems we are quite lucky on this forum as there is never a shortage of advice & information  [-/
Just out of interest a guy over the road has got an old Porsche 911 & he was having probs with the starter motor wiring. He found a web site & posted his problem. The guy got back to him & said that he knew exactly what the problem was , just send £12.50 & I will tell you. B*****ks he said !
When he told me I said that he should find a decent Porsche Forum & get on there.
Following day I saw him looking happy as Larry , Got it sorted he said, found a forum & got the answer ..................................................... & the guy only wanted £5  :oops:
« Reply #10 on: July 09, 2009, 08:57:23 AM »
sorry  :oops:  but i still think its a contact issue somewhere, try taking the wire on the switch off, connect it to 12v and see if it works, if it does its the switches, if not move on...  [-/
good luck
« Reply #11 on: July 09, 2009, 09:33:28 PM »
i had a simailar light problem in an old bis i had and found that it was wear on the connectors in the stalk arrangement the only way i could sort it was to replace the lot and i warn you its a crap job to take it all apart!!
defender90
« Reply #12 on: July 10, 2009, 11:14:26 PM »
Bis 13 I wasn't being pedantic! and you seam to have missed the point all together.
  He was stating that his DIPPED beam elements do not work on the switch but when he pulls his stalk the DIPPED beam elements do work! I asked the question do 126's flash their headlights on DIPPED beam because all other cars flash their headlights on FULL/MAIN beam not DIPPED and he has answered yes UNLIKE ALL OTHER CARS 126's FLASH ON DIPPED BEAM!
 Now I ask who's the pedantic 1???????????
Kevan
Radcliffe
Gt.Manchester
Citroen BX TZD
« Reply #13 on: July 11, 2009, 04:10:00 PM »
yep your right of course . [-/ it would SEAM....markie at the end of the day i suspect your problem is a worn out connection in the stalk i had this before on a bis i had and also jorge had the same problem and both had to replace the whole stalk group on the steering column which is a crap job to do.
markie
« Reply #14 on: July 12, 2009, 07:02:57 PM »
Hey guys, Thanks for the interest in this but I still have the issue, I have dismantled the switchgear and luckily have a set of nuts and bolts that have replaced the rivets that I drilled out perfectly and the outcome is that the switch gear seems ok I have good continuety through the contacts but still no Juice running back to the fuse box via the red and gray wire to feed the gray and gray/black wire to the dipped beam, c'mon guys, put yr heads together.  ???
