Author Topic: BIS gears help!  (Read 2810 times)
kb
BIS gears help!
« on: July 02, 2009, 05:29:21 PM »
Hi I'm new to this forum....
Just got my BIS up and running thanks to my dad....
I can't get her into reverse, and to get it into 4th you really have to snatch the gearstick back really quickly...
Any advice?
Thanks in advance!  :)
Re: BIS gears help!
« Reply #1 on: July 02, 2009, 06:09:14 PM »
it sounds like the adjuster needs playing with are you having any problems with first? and please remember 1st gear is only for pulling away and never change down to 1st gear unless you are stationary!!!
kb
Re: BIS gears help!
« Reply #2 on: July 02, 2009, 06:14:06 PM »
Yeah I've been given a whole lesson in first gear already :)
kb
Re: BIS gears help!
« Reply #3 on: July 02, 2009, 06:14:56 PM »
first is fine, it's 4th and reverse I'm having trouble with and occasionally 3rd too :(
Re: BIS gears help!
« Reply #4 on: July 02, 2009, 08:30:39 PM »
has the engine and gearbox been out of the car? if so it might be that the gearbox position is slightly different now and so the adjustment of the selector is now out slightly not meaning to sound off but have you made sure the clutch is also adjusted properly as it can make gears crunchy if just a little out too.
kb
Re: BIS gears help!
« Reply #5 on: July 03, 2009, 09:56:49 AM »
Thanks for your help! Looks like this will become this weekend's project! :) Will keep you posted!
Re: BIS gears help!
« Reply #6 on: July 03, 2009, 10:49:42 AM »
check the linkage isnt loose under the car and make sure you are using the shouldered bolts as the make a big difference!
fightingtorque
Re: BIS gears help!
« Reply #7 on: July 03, 2009, 12:23:29 PM »
Double de-clutching  works too.  The gearing in general is quite long, sometimes I think you do need to drop back to first.
Re: BIS gears help!
« Reply #8 on: July 03, 2009, 10:46:38 PM »
but its got a syncro gearbox ? i do sometimes tend to take gears in a two motion action though like i deselect pause in neutral and then select the gear but i dont release the clutch or rev as dble de clutching.
kb
Re: BIS gears help!
« Reply #9 on: July 06, 2009, 10:09:23 AM »
I have reverse now! wooooooo! No more embarrassing moments of pushing her along! :) Thanks guys!
Andi
Re: BIS gears help!
« Reply #10 on: July 06, 2009, 12:00:55 PM »
Congratulation!
But i want to add a clue:
If 4th. and reverse is missing, the engine/box is twisted clockwise, looking from behind. This can have two reasons: Gearbox-gums fixed in the wrong position, or (the right one) broken.
In this case you'll find the gears, if someone pushes the engine down on the left side.
Ah, ok, it's a BIS. Then forget the wrong-position-thing, but have an eye on the broken one...
« Last Edit: July 06, 2009, 12:03:42 PM by Andi »
Re: BIS gears help!
« Reply #11 on: July 06, 2009, 10:40:35 PM »
with double de clutching youre not suposed to on the 126, in fact i think it might even damage the synchomeshs it says in the handbook not to double de clutch, only 500 gbox must you ddc?
also yes be careful with clutch adjustment, i dove my BIS with cable not adjusted and it caused my 1st to crunch and finally lost that gear. so get it adjusted.
« Last Edit: July 06, 2009, 10:42:16 PM by Chris Lakin »
Gregozo
Re: BIS gears help!
« Reply #12 on: July 09, 2009, 09:26:17 AM »
KB can I ask how you solved the problem? Yesterday I had reverse, today the gear lever goes into the reverse position but car goes forward in 4th (I think) and no reverse light either. Thanks
Gregozo
Re: BIS gears help!
« Reply #13 on: July 10, 2009, 01:42:17 PM »
Further to last post, I have done some checks and nothing obviously wrong. Got the cover off the selector in the car and that looks OK. Car drives OK but to get 3rd have to depress gearstick to engage, same for 4th which is where reverse used to be. I see on the parts drawing there is a 'flexible' coupling - do these fail / wear out. Visually it looks OK. Anyone any ideas?
Re: BIS gears help!
« Reply #14 on: July 10, 2009, 02:28:36 PM »
Just had a similar problem on mine, check the gearbox is sitting central in it's mountings.
Mine was sitting up on the left hence the gear shift had to go further than intended to get third fourth and reverse.
All I did was loosen them off , then rock the engine so equal gaps in the gear box mounting slots, it's perfect now!
