Author Topic: handling compared to a mini?!  (Read 2377 times)
mic
« on: July 01, 2009, 05:43:36 PM »
had a few minis over the years but never even been in one of these  :D is there much difference in them for handling?!
Re: handling compared to a mini?!
« Reply #1 on: July 01, 2009, 06:01:46 PM »
I can do 40- 60mph round roundabouts (depending on their size) with no slippage? is that a good benchmark? :D
ask mick really he is the 126 hoon-master...
« Reply #2 on: July 01, 2009, 06:36:27 PM »
Being a "blood relative" of the original Fiat 500 that shocked the world by having independent suspension all round over 50 years ago, the 126 is a little more robust & if you get kitted out with some wider boots it will go right where you point it, the hard bit is making it go there faster if that is your bag  [-/
« Reply #3 on: July 01, 2009, 07:23:28 PM »
the 126 handles really well, well compared to a cinquecento (only other car ive driven for a longer distance) it has really firm suspension, only minus is driving in the rain, when you have to be really carefull in sharp bends, i would know...  :P
defender90
« Reply #4 on: July 04, 2009, 11:01:05 PM »
126 will never be as good as a mini for handling but what car is? If memory serves me well the faithfull Mini is like poop on a blanket!
« Last Edit: July 07, 2009, 10:17:56 PM by defender90 »
Kevan
Radcliffe
Gt.Manchester
Citroen BX TDG (soon to go)
Citroen BX TZD
Land Rover 110 Station Wagon
« Reply #5 on: July 04, 2009, 11:33:10 PM »
imho the mini is just too popular and based on what? i dont like it that much, never driven one and never problee will, if i wanted a reall fast small car id go for a 500 abarth (new or old), the italians know and knew how to make small cars, all the other stuff fades in comparison...
« Reply #6 on: July 05, 2009, 12:00:05 AM »
I thought the mini suffered from understeer..my personal opinion as I'm no expert. Might just be my driving  :oops:
Always felt I had to lift my butt off the seat in a mini  over bumps :P
The 126 carries amazing cornering speed in the dry, let down by lacking horsepower on the strait bits, so keep your speed up in the corners becomes a way of life. As to be expected it suffers from understeer in the wet as the front is light. ;) but then being less agressive with the wheel helps... until one hits the green tar ..then all four wheels loose it :oops:
I think the mini gets top marks for it's racing successes.
I've always found the fiat to go where I point it and a delight to have such light steering.
I just wish my fiat didnt break as much  :oops: maybe I'm just going through a patch of finding-out the problems, but then my mini exhaust manifold brings back nightmares I could never forget :o
Done 6800 miles this year since october 08 so not bad going I guess, never had to walk  [-/
Tomasz
« Reply #7 on: August 04, 2009, 11:52:26 AM »
I was not a mini fan until recently when i got the one intended for emma's sister on the road. I have been driving it for about six months and it really is great fun.  It is lowered though so i suspect if my 126 was also lowered they would be pretty close 'fun-wise' .126 gets extra point for being rwd!
I am actually selling thee mini now and trying to get other cars out of the way so i can spend time on the 126.
phreak97
  • Niki!
« Reply #8 on: August 09, 2009, 01:18:18 AM »
I work at a mini specialist workshop, and from what I've seen minis can stick to the road much better, they have a wider wheel base, and no silly positive camber, the rear wheels on a mini have trailing arms that hinge parallel to the axle, so the camber never changes regardless of what the suspension is doing. I suppose if the 126 was lowered that self adjusting camber would help keep the wheel flat on the road when the body rolls.. but I find in my 126 the rear wheel on the outside of a turn feels like it's tucking under the car if I go fast.
Minis have indipendant suspension all round too if you have rubber cone suspension, and if you have hydrolastic then you dont want indipendant anyway, the hydrolastic system links the sides of the car up so if one wheel is moved up the opposite wheel on the same side of the car will move down, this is meant to keep the car quite level and provide a soft ride while almost completely removing body roll (you cant move two wheels on one side in the same direction).
My Morris 1100 has that and it isnt quite as amazing as they advertised, but it sure is bloody nice compared to other cars of that era.
minis have heavier steering and a bigger steering wheel, if you put a smaller one on it becomes very heavy steering, and if you put boss kits etc on there for different steering wheels you end up half a km away from the dash..
also I'm always afraid of tipping a 126, where a mini has never worried me once, and also I dont know why someone said minis suffer understeer.. theyre front wheel drive! just put your foot in and it pulls the car around.
in the end though, I like my 126 better, it's comfier and I think it's more fun to drive even if it isnt superior around the track:P
phreak97
