Author Topic: long time no start!  (Read 2372 times)
long time no start!
« on: June 23, 2009, 11:20:52 PM »
hi all,
ive just tried starting my 126 aircooled - first time in just over a year.
batt was dead so charged it over night, starter motor wouldnt turn i've got a recon one im going to fit.
i also put 5 litres of fresh fuel in
Could it be the nackered battery even though its been charged? not holding enough juice to turn starter?
any suggestions or tips would be appreciated.  :D
Regards
Re: long time no start!
« Reply #1 on: June 23, 2009, 11:39:51 PM »
try jumping it off another car (directly connect it without your battery in the loop) this will identify if you battery is at fault...
nrg19uk
« Reply #2 on: June 24, 2009, 06:35:17 PM »
give the starter a tap with a hammer
Neil gargaro
« Reply #3 on: June 24, 2009, 08:27:42 PM »
Hy chris, try what Stuey said, had the same problem when i bought my bis, replacig the batt solved it, either that or the starter cables might have dropped off (this too happened to me)...
Jan-in-UK
« Reply #4 on: June 24, 2009, 09:12:14 PM »
Chris, are you from Uxbridge? Just a second from Slough. Let me know, I have cables and I could come with help anytime you need it. Cheers.
www.fsoclub.co.uk
« Reply #5 on: June 24, 2009, 10:58:44 PM »
youre all right!!! ;D
was just the battery!! i picked up my new battery from Halfords tonight, connected it and it started first time!
i even took it for a quick spin round the block, amazing! just love it! i've driven alot of cars an nothnig compares to a 126!
my new bakerlite fuel pump spacer, pump rod and starter lever clip arrived today from Ricambio, so i will be fitting that over the weekend.  Im currently using a torque wrench to push the starter motor to get it going so will be nice to start it from the cockpit again!
Thanks for all your input, next step is to get it MOT'd, taxed and insurerd.
Jan, yes im only in Uxbridge, so we'll have to meet up soon! your 126 looks great, cant wait to see it!
Regards
« Reply #6 on: June 25, 2009, 08:47:12 PM »
dont forget chris dont put metal on the starter motor get a broom stick!!!! ;D
« Reply #7 on: June 26, 2009, 10:40:31 AM »
hahaha!
i've been using a bloody metal torque wrench and jack handle!   O0 lol
youre all thinking....Amateur yes youre right!
i fixed the starter cable though last night, so i can now start the car from inside the cockpit. It was the little white plastic clip that the outer cable clips into. These often become brittle and break off. Stupidly the plastic clip fixes up into the hot air tunnel whcih takes hot air into the car. The heat make sit go brittle over time.
Regards
« Reply #8 on: June 26, 2009, 03:51:45 PM »
man doesnt have that kind of problems on a bis...  ::) :D
post a few pics chris, itching to see what your pull-lever-started-lawnmower looks like :D
« Reply #9 on: June 26, 2009, 08:00:57 PM »
ys i miss my bis, still got it but engine is out, need to put it all bk together.
i'll get some pics sorted, its a 1976, with 98k on the clock fairly gd condition tho considerin the mileage.
Rgds
« Reply #10 on: June 26, 2009, 11:37:06 PM »
i have a brass part instead of that useless plastic bit i will dig it out and let you have it if you want?
« Reply #11 on: June 27, 2009, 11:17:06 AM »
hi mick
i didnt realise they did a brass one, thats great. They a polish upgrade?
If you have one spare i would be grateful, its the second time ive had to replace it.
