Author Topic: speakers, doors and noise  (Read 2549 times)
The Doctor
« on: October 28, 2005, 06:34:49 PM »
Hi Milky. Welcome - this club is great!
Question to our many experts please - can I fit flat speakers in the doors, if so, how do I get the window winder handles off? Also, my engine seems to be very noisy even when hot.  Is this normal or do I have a problem?
Asked Car Mechanics magazine, but they said they had nevre worked on a 126 and as none had been importede into the UK, they had no technical info! Could this be correct? Thanks everyone   :?:
you can do it in a 126 (I have!)
« Reply #1 on: October 28, 2005, 06:47:59 PM »
hi m8! the window winder handles are a tricky one but quite easy onece explained, remove everything that comes off/pops off, then underneath the handle is a little wire piece which is clipping the handle together, get a paper clip or somthing of the sor, make a hook end and try to pull it out, once its out you can rmeove the rest. I hope this helps its hard to explain without me looking at mine now, but from memory the above is correct.
About the speakers i have seen it done, but im thinking where is the wire going to come from? to conect the speaker to the radio? do you see what im saying? it will have to go over the door pilla as there is no where else for it to go?
i hope someone else can guide you to, anybody????
toz
« Reply #2 on: November 06, 2005, 03:56:42 PM »
hi,iam hopeing to fit some door speakers to my convertible.underneath the handle is like a horse shoe clip,i use a special tool at work but have found that a flat electrical screw driver  can do the job.use at one end of the clip and push it off,take it off and the rest of the handle but if you can put some masking tape, or carboard round the area so you dont scratch the door pocket.i will drill one hole through the middle of the door underneath the check strap,and the other through the other post.i will then thread it through the dash where you cant see it. to cover the wire through the post and the door you can get rubbers from cars in scrap yards that have speakers in the doors or elecric windows.(the hole just needs to be big enough to get the gromits in each end.hope this helps. :cool:
