Author Topic: Running Problem idles but no rev increase  (Read 3413 times)
126-Pilot
« on: June 17, 2009, 10:12:31 AM »
Can anyone please help. I have a 126 deville 650cc.
Its just a little project, it used to run fine however now i can get it to idle ok/rough but when i press the accellerator it does not increase revs it either pops a bit gets rougher or stalls completely. I have changed plugs, fuel, rotor arm, filters air and fuel plus I have had the carb off and stripped and cleaned.
The only other thing I can think is timing and valve clearances, how likely is it that either of these is causing the problem?
Many thanks - please help a newbie!!
Re: Running Problem idles but no rev increase
« Reply #1 on: June 17, 2009, 10:25:33 AM »
Check or replace the points, set up the static timing, if that does'nt cure it clean out the carb [-/
« Reply #2 on: June 17, 2009, 10:42:03 AM »
i had similar probs with my bis, id say its the carb, either have it looked at/restored by a pro or buy a new one. and doing what pete said cant hurt either  :)
Andi
« Reply #3 on: June 17, 2009, 04:00:10 PM »
Just an idea: The air from the vent-housing to the airfilter is limited by a calibrated tin. Sometimes this falls off, and then the air to the carb is too much. If you can't find the fault, you could look for this one.
« Reply #4 on: June 17, 2009, 10:28:23 PM »
try your fuel pump and see if its working okay this is sometimes how it reacts when the pump has had it ,idles but as you want more revs it just cant do it as the pump cant supply the fuel .
« Last Edit: June 17, 2009, 10:32:13 PM by bis13 »
Landy-Pilot
« Reply #5 on: August 03, 2009, 11:14:30 AM »
Thanks all not been on here for a long time had to get a new computer! after paying some fool to mend it rather than just telling me it I was on a hiding to nothing!
Anyways I will try everything suggested. Any idea how much it would cost for the carb sorting by a pro? Also is sorting out the timing fairly simple and can I do it without one of them strobe thingymibobs?
Also how can I test the fuel pump I did check it pumped fuel through but I dont how to test how much it will pump.
Thanks in anticipation :)
« Reply #6 on: August 03, 2009, 11:52:04 AM »
Have you got a haynes manual , if not even the earlier ones (594ccs engine) that regularly go for 99p on eBay will help you do most things. A 126 engine will run & rev on a full float chamber for a short time. Yours will not rev so the fuel pump is probably OK. Try running without air filter just in case it is clogged. Otherwise you may be drawing in air at the base of the carb. Check the flatness of the carb mounting flange with a straight edge across the widest part. Check the gaskets & the drip tray for cracks.
The guy I got my car from had just had the carb "serviced" by a well known Fiat specialist garage & got a £220 bill . The work was worse than utter crap & I had top do a full complete rebuild myself so be careful with that one.
Have you changed the condenser, the weak link in the ignition set up ?
Also plug leads break down after time.
If your points gap is OK & the timing is there or there abouts it should rev & unless the valve clearences have been messed with & the car was running OK that is probably not going to be your problem, good luck  [-/
Landy-Pilot
« Reply #7 on: August 03, 2009, 05:07:46 PM »
Not changed the condenser will have to look into that where can I get one non listed on ebay :D
Also ive not changed the ignition leads, the 2 plug leads look ok the coil lead looks pretty ill however. No one seems to list a coil lead any idea where I can get one? I was gonna take the one which was on it to a motor factor to check against theirs but it doesnt look the correct one anyway.
« Reply #8 on: August 03, 2009, 10:22:02 PM »
my bis spluttered once, it was the condenser loose, might be worth changingit anyway.
i think everyone has covered most of the possible problems, let us know if its not solved by doing any of the things already suggested.
Im sure you will get it resolved.
Regards
« Reply #9 on: August 04, 2009, 03:43:45 PM »
If you are having trouble getting parts then I took a good set of leads & condensor off my car when I fitted electronic ignition, they are available & could post for £10 all in  [-/
phreak97
  • Niki!
« Reply #10 on: August 09, 2009, 01:49:22 AM »
the leads arent a special type.. you can take your old ones in to any automotive shop and theres a pretty good chance theyll be in stock, it's just that alot of places will throw your car in the too hard bin as soon as you tell them what it is just cos they dont know what it is.
I'm guessing you've tried adjusting the fuel mixture screw?
for static timing: the way I do it is I turn the ignition to the on position, put the car in 4th on a flat area, take the engine cover right off, then roll the car forwards until the mark on the crank pulley is visible, then keep going listening very carefully (you can roll the car with one hand while sitting down behind it, theyre light as anything) and as you roll the car so the pulley mark moves past the lines on the motor youll hear a click from the distributor, now roll the car back so the mark is before the lines again, loosen off your distributor nut , turn the distributor a bit, and do it again to see where the click is this time.. you want the click to happen right when it passes the line on the engine. there are a few lines on the engine, I use the first long one, but I dont know if that's correct, maybe someone else can help with that? always runs nice using that one though.
phreak97
