Author Topic: Coolant Light...  (Read 1684 times)
rizlarizla
Coolant Light...
« on: June 15, 2009, 03:46:28 PM »
to set the scene...(never had this problemo before..but now....)
whilst the BIS is idling i get no light...when i drive i generally get no light, but whenever i go over a bump or us the brakes firmly the light goes on and then goes off...
should i check the coolant levels (how to do this- nothing visual to check?)
is this an easy fix?
Any ideas / options??
(the swap to an aircooled model did cross my mind - but no cash for this and would need to sell the BIS before i even thought about it...convincing the Mrs however would be the hardest bit )
Re: Coolant Light...
« Reply #1 on: June 15, 2009, 05:03:23 PM »
Dont sell your bis just look after it!
The coolant level is by mechanical sensor so when you go over a bump it slops around and goes below the level it should bit like in a fuel tank, you could top up a little but I don't thin it's a problem.
rizlarizla
« Reply #2 on: June 15, 2009, 05:24:07 PM »
i am trying to look after my BIS- honest.  :)
- how do you tell if you have too much coolant/water if i need to top up?
(obviously - just for the smart alecs out there :P - i will know when i have too much since i will see the water come out of the filler....) LOL
« Reply #3 on: June 16, 2009, 07:10:43 AM »
You don't, the idea is that you fill it until the coolant light goes out on the dash.  If it comes on again you top up till it goes out.
rizlarizla
« Reply #4 on: June 16, 2009, 08:52:57 AM »
hahahah  ...I like the very scientific method... :) :)
cheers for the pointers....at least there is nothing i have to reapir....!! phew..
« Reply #5 on: June 17, 2009, 10:40:00 AM »
what i do is fill it up untill it starts pouring out, then just squeeze the big coolant pipe on top of the engine so a little comes out... is this wrong by any chance?  :oops:
