Author Topic: small parts required  (Read 1308 times)
chipuk
« on: June 10, 2009, 09:27:12 PM »
HI.
i am after a few small parts for my 126 engine Its the 652cc 1979 engine.
I snpped a stud on the alternator pulley so im after a pulley ( i have a 500 dynamo but according to axels site they are not the same as mine)
Im also after the spring that returns the fin with the thermostat rod attached to it ,  the spring is in the bar attached to the tinware
I can order the bits from axels , but just wondererd if anyone had  s/h bits i can buy
steve
chipuk
Re: small parts required
« Reply #1 on: June 11, 2009, 08:37:30 AM »
Ive just noticed ive put down pulley , i think its actually called a hub? Its the part that has the 3 studs in it and is held onto the alternator by a 19mm centre not
« Reply #2 on: June 13, 2009, 11:47:29 AM »
hello mate i have a spare alternator thats got to be refurbed i will let you have the hub you require . i will see about the spring .
chipuk
« Reply #3 on: June 13, 2009, 07:54:21 PM »
HI Mick.
Got it sorted today. Many thanks for the offer.I rang franco at ricambio and he sorted a spring out for me.
Fingers crossed, engine goes back in tomorrow. I only took it out to change the flywheel and to have the tinware powder coated
Rgds Steve
