Author Topic: Head gasket question.  (Read 1790 times)
« on: June 10, 2009, 12:38:00 PM »
 O.K. guys, I know this might sound like a stupid question, but could you tel me which one is the way up for the head gasket? There is no marking on it at all. I`m assuming is pic. no. 1, but not 100% sure.
 Thanks for any help.
Andi
Re: Head gasket question.
« Reply #1 on: June 10, 2009, 01:33:35 PM »
If i wouldn't use Cu-gaskets, i'd join number 1, too. But thank god i never had to decide this. Cu-gasket is one of those investments that really make sense. But back to your ask: I'd install the wide ring top, because the alu of the head is softer than the steel from the cylinders, so it'd be good, if there was more material. I assume, that an original gasket would be symmetric, so there's no need for a marking. Thats my thoughts... :-
« Reply #2 on: June 10, 2009, 07:20:50 PM »
theres normally some sort of a stamp on top and you just have that facing up, i just looked at one with the stamp and it is the surface with the wider metal ring on top.
Andi
« Reply #3 on: June 10, 2009, 07:22:03 PM »
« Reply #4 on: June 10, 2009, 09:12:37 PM »
 Thanks guys [-/ This head gasket didn`t have any stamp or number or anything at all...
Andi
« Reply #5 on: June 11, 2009, 05:16:00 AM »
I wonder, why most Fiat Twin-drivers don't join the advantage of a copper gasket. There's only one minus, and that's the price, wich is relative, because smoking 20 cigs a day isn't cheap, too. And latest at the next gasket quit, the money would be in again.
- copper gasket is endless reuseable, just glow before fixing.
- no tighten up after some 100 km. Just fix and foxy.
- does not blow out like this stupid paperboard.
There are different thickness of copper gaskets. All you have to know is, that head gasket + foot gasket together have to be 1mm. Less will cause piston/head contact. So, if you have the original footgasket of 0,3mm, you need a 0,7mm head gasket. I prefer to renounce the foot gasket , and use silicon instead. Then my head gasket has to be 1mm.
