Author Topic: Disk plates  (Read 2729 times)
Disk plates
« on: June 08, 2009, 04:51:18 PM »
Plates for using CC calipers and disks on a 126. I am getting some (just picked up some CC brakes on Ebay for a fiver).
Guy in Poland does them for about £15 a set plus postage. If I order more it will work out cheaper.
Anyone interested????
Re: Disk plates
« Reply #1 on: June 08, 2009, 06:41:20 PM »
do you mean the dust cover bits that go on the back?
Re: Disk plates
« Reply #2 on: June 08, 2009, 08:14:21 PM »
he is talking about the conversion plates .
Re: Disk plates
« Reply #3 on: June 08, 2009, 08:33:00 PM »
ah ok got them already ta!
rizlarizla
Re: Disk plates
« Reply #4 on: June 09, 2009, 09:24:30 AM »
hi Dajwid
Are these the plates used for any for any brake disk set conversion?
I have  a set of siecento brakes disks and hubs and still need to get these plates to allow fitting...wondering if they will work..?
Was trying to get a hold from TRS in Poland but they have none yet...i think there may have been a few more poeple who wanted these plates - if they are generic?
Riz
ps - do they by any chance come with instructions on how to fit?
Re: Disk plates
« Reply #5 on: June 09, 2009, 04:42:21 PM »
I am told they cover CC and siecento,they are galvanised, there are no instructions.
Re: Disk plates
« Reply #6 on: June 09, 2009, 05:33:36 PM »
 :) After being loaned one of the TRS adaptor plates recently and buying a variety of other bits I was at last able to bolt together a complete assembly which currently sits on my dining table. Observations were , I can see no reason for some of the perimeter shape, the laser cut holes only just matched those on the stub axle and were on the limit of needing drilling or filing out to get a fit, if bolted up as is then the disc fouls the caliper carrier so this has to be packed out with washers. The TRS plate is 5mm thick , a slighly thicker plate would cut down on the number of washers required. I am guessing that Stuey has been through all this . Apart from that it all works . To reassure Riz I bought a pair of Cinquecento and Seicento calipers & they are exactly the same so you have no worries there. I have been working on a plate design myself but have not yet got a price for the laser cutting but I suspect that £15 plus costs is not a bad price so I would be up for a pair even if it is just to compare designs  [-/
Eklipze3k
Re: Disk plates
« Reply #7 on: June 09, 2009, 05:43:25 PM »
Count me in :)
baked one
Re: Disk plates
« Reply #8 on: June 09, 2009, 06:13:18 PM »
yeh these sound great il buy a pair saves me tryin to make some  :D
Re: Disk plates
« Reply #9 on: June 09, 2009, 08:46:32 PM »
i will have a pair too please  [-/
rizlarizla
Re: Disk plates
« Reply #10 on: June 10, 2009, 08:58:17 AM »
Rusty's Uncle - Thanks so much for the double check !
I feel happier that you have had a look and say it should be ok to use.
Dajwid - me is a definite!  :)
landyman
Re: Disk plates
« Reply #11 on: June 10, 2009, 11:26:18 PM »
put me down for two sets please! has to be a sensible move forward from shoes/brake fade
