Author Topic: Head ache :-(  (Read 2039 times)
Head ache :-(
« on: June 06, 2009, 11:59:18 AM »
Belt snapped (OK! I know) drove about a mile home( (yes again I know), Very hot, Oil all over my shiny engine!!
Boll**ks!!!!!!!
Gasket or head? The fun begins.
On the plus side it could have happened on the M1 on the way to Billing :)
Re: Head ache :-(
« Reply #1 on: June 07, 2009, 09:37:57 PM »
chuck a belt on it and see if the hollow bolts are pushing out gas if not its all pushed through the crank case into your catch tank and out via the filter if not its blown your dipstick out and sprayed oil around either way at least the engine bay wont rust.!
Re: Head ache :-(
« Reply #2 on: June 08, 2009, 03:37:33 PM »
Belt on, runs fine, nothing in the catch tank (looks pretty though) Definetly looks like it is coming from the head. Do I need to take all thr tinwear off or can I change the gasket with it on????
Re: Head ache :-(
« Reply #3 on: June 08, 2009, 08:32:23 PM »
well if you have oil coming out near the head it must be from either the push rod tube seals or the gaskets that are underneath the piston barrels the later means muchos grandos turdos. have you had a good look at the rocker cover gasket as that could have been cooked and is leaking ?
Re: Head ache :-(
« Reply #4 on: June 08, 2009, 09:03:08 PM »
Took off the tinware thermostat side, looks like 'I hope' it is from the rocker gasket, but hard to see as pretty messy.
Taking it all off I noticed I need a new exhust and thermostat. So shopping again :-)
Re: Head ache :-(
« Reply #5 on: June 09, 2009, 08:46:19 PM »
Looks like pushrod seals, Oh shi* am I going to mess this up??
I was hoping for a nice easy rocker cover gasket job.
How much of a job is this?
I am more of a tinkerer, as my daughter 8 year old rightly pointed out today, "why are you pretending to be a mechanic"? "You can't be a proper mechanic because you wear glasses".
I assume better to do head gasket and all gaskets/seals at the same time????
Re: Head ache :-(
« Reply #6 on: June 09, 2009, 08:57:45 PM »
ha ha out the mouths of babes eh? you need to pull the head off to replace the push rod seals so that means a new head gasket anyhow if you need to replace the lower piston barrel seals then you need to remove the pistons if your doing that then you need to measure everything to make sure its all pukka so all in all its a complete engine overhaul if you want to do it properly but dont worry they aint that complicated just make sure you mark and bag everything and keep a log of everything you do. or you can just cheat and replace only the minimal but then run the risk of having the lower seals leaking...its up to you. and if you have trouble just ask us or theres always your daughter. ;D
Re: Head ache :-(
« Reply #7 on: June 14, 2009, 09:58:16 PM »
OK job done!
Push rod seals replaced they had just gone brittle and 2 were leaking.Head gasket changed. all put back, Tons of swearing. No bloody knuckles left, Felt like cutting a hole behind the rear seat to get the last few bolts back in.
Started great.
BUT! Always a but.....
I had a hell of a job getting the rear engine mount (the sprung one) back on. It's on but it rubbing on the manifold.
Engine now seems too far back, Also jumps out of gear due to the same problem. Where did I cock up???
« Last Edit: June 14, 2009, 10:00:42 PM by dajwid »
Andi
Re: Head ache :-(
« Reply #8 on: June 14, 2009, 10:50:29 PM »
As i can see, there's a washer missing under the head of the screw. Did you mount it on a wrong place? Compare your assembling with a click of the picture in this link! http://fiat500-fischer.de/product_info.php?cPath=141_38_100&products_id=809 If it's mounted in the right order, there's about a 2-3mm between manifold and the big plate.
Check the gearbox-rubbers, if they are broken. This could be the reason why the engine is too back and due to this the gears jump out. And while you are under the car, check the Lolly, too. Gearlever has to be 90° vertical in neutral.
BTW: I'd terminate this silver intake silencer. It looks like it knocks at the tin above. I couldn't live with that noise! Replace it with a simple tube. That's original on the early models.
BTW2: Put the rubber caps of the spark plugs right into the holes! There's a lot of cooling air going lost!
« Last Edit: June 14, 2009, 11:04:17 PM by Andi »
