Author Topic: Installing a Cigar Lighter  (Read 3005 times)
Eklipze3k
« on: May 05, 2009, 12:34:40 PM »
Anyone done it that has a 27mm holesaw I could borrow ;D
Seems a bit daft to pay nigh on £15 for the saw and arbor just to make 1 hole  :o
Andi
Re: Installing a Cigar Lighter
« Reply #1 on: May 05, 2009, 02:18:03 PM »
Eklipze3k
« Reply #2 on: May 05, 2009, 02:56:39 PM »
Ahh but that also involves buying a Dremel ... which I can't afford right now ;)
« Reply #3 on: May 05, 2009, 03:46:39 PM »
lol. try a scalpel then? just cut out a hole, smaller than the outer edge of the cigy lighter, and push it in?
where may i ask do you plan to put a lighter on a aicooled? 8)
Eklipze3k
« Reply #4 on: May 05, 2009, 03:50:19 PM »
A scalpel? Through metal?? I'd be there for a month!!  ;D
I'm installing it just to the right of the steering wheel, I used the scalpel to cut away the foam faux-leather stuff and have drilled a pilot hole, I guess I could increase the size of the pilot hole and just go at it with a hacksaw blade, it won't be pretty but I don't suppose that matters as long as it holds in tight  [-/
Andi
« Reply #5 on: May 05, 2009, 05:45:50 PM »
I once had a situation like you: No tool, no time. I took an old hexagon socket, formed four teeth with my Flex, and welded a drill into the square. For one trial it will work.
« Reply #6 on: May 05, 2009, 05:52:17 PM »
ooo... youre drilling thru the metal... the bis has a plastic circle that is supposed to house the lighter...
....wait.... you are actually drilling a hole on a beautiful, old school, 126?? blasphemy...!!!  :P :P :P
Eklipze3k
« Reply #7 on: May 05, 2009, 06:02:37 PM »
I know :oops: but I already had to fettle the engine bay a little to get the new exhaust to sit properly so the blasphemy has already commenced in earnest, and at least this is useful for more reasons than just smoking (which coincidently is not something I do)  [-/
Eklipze3k
« Reply #8 on: May 05, 2009, 06:03:15 PM »
That's an excellent idea :D
Eklipze3k
« Reply #9 on: May 07, 2009, 09:08:58 PM »
I eventually decided to just use the biggest standard drillbit I could find in the shed and a hacksaw blade. Then once the majority of the hole was open smoothed it out with a file and popped it in - sorted :)
Should have got a pic, I'll grab one tomorrow  [-/
phreak97
  • Niki!
« Reply #10 on: June 10, 2009, 01:24:37 PM »
argh, no holes!! you should have made up a mounting bracket to fit some existing screws.
my aircooled has a plastic plug in the centre console which you pop out to put in a cigarette lighter.. but it's got a late interior
phreak97
