Fiat 126 Chat
BIS Juddering BADLY on take off and popping first gear...
Pages:
3
Topic: BIS Juddering BADLY on take off and popping first gear... (Read 7549 times)
Re: BIS Juddering BADLY on take off and popping first gear...
Reply #30 on:
May 22, 2009, 09:34:30 PM »
i am a right tightwad and used a length of clear tubing and an old litre oil bottle with the tube taped to it and fed using gravity, chuck what it says in the manual and get it from fiat then you cant go wrong. as for undoing the filler plug then its best to jack the car up remove the plug then let back down again and then fill it up. if you cannot get the plug undone then theres little places where you can fill the gearbox and diff up from one is undoing the inner drive shaft gaiter and removing a stud and using the hole as it goes right through the casing.
Crxsprocket
Member
Reply #31 on:
May 22, 2009, 10:19:35 PM »
Similar to Bis13...I use an old Castrol 500cc fork oil bottle which has a built in tube about 6" long and when fill with oil, can be squeezed to fill the gearbox...Fiat 500, 126, Peugeot 106 et al....
Adzdum
Member
Reply #32 on:
May 22, 2009, 11:45:55 PM »
Excellent cheers for the DIY tips!..
although I already ordered the proper tool off my mate who works at a motor parts place. It's only a tenner so not too bad!
I have finally found a use for the old 'Gator Grip' in my tool box!.. It was perfect for removing that square plug!
Andi
Reply #33 on:
May 23, 2009, 07:06:16 AM »
You can use a 1/2" socket to remove the plug! Square to square, and an inbus to the hexagon. For filling in the oil i use a medical injection, which is for free, for my wife is a nurse...
Pages:
3
Fiat 126 Chat
