Author Topic: BIS Juddering BADLY on take off and popping first gear...  (Read 7549 times)
Andi
Re: BIS Juddering BADLY on take off and popping first gear...
« Reply #15 on: May 05, 2009, 01:40:33 PM »
This could be also the reason, yes, but in both cases he has to screw out the engine, and at that point it's an easy to check the box, too. He first has to face a little work to find his problem, and then looking for solutions.
I order my poland-parts from my friend Adrian, who is member of this forum, too. His email is [email protected] . He speaks english.
Adzdum
« Reply #16 on: May 05, 2009, 03:34:53 PM »
Thank you all for your input so far!  I am building up a nice little list of things to check when I take the engine out.
I've ordered some new gearbox mounts as Mali suggested as mine are shot.. so I can change them at the same time.
Bis3.. I have noticed quite a bit of oil on the underside of the engine.. so I know need to be looking for a leak.. that may possibly have gotten onto the clutch plate.  so I will (depending on cost) just replace the gearbox oil seal while he box is off..
The clutch plate itself maybe worn or just needs replacing due to oilage.
I need to check the teeth on the first gearwheel as suggested by Andi.
And finally if all that seems to be ok.. I may have the same problem as Gordan and his loose nuts!.. in which case its gonna be a gear box strip down to find out!.. fun fun  ;)
I now have access to the subscribers download area.. so I'll get studying the manuals and I may even have a crack at it this weekend if the weather is good!
I'll let you know what I find!
Thanks,
Adz
« Reply #17 on: May 05, 2009, 10:28:47 PM »
keep an eye out on ebay as there are a few clutch plates only that turn up from time to time i got one for a fiver which cant be bad.
« Reply #18 on: May 05, 2009, 10:32:45 PM »
About that oil-on-the-clutch part, my clutch housing is filled with oil, and there are no problems, im telling you its that nutty problem i had...  :D
Adzdum
« Reply #19 on: May 09, 2009, 09:13:51 PM »
Just a quicky!... The BIS manual downloads in the subscribers section doesn't cover the gear box.. Would I be able to use the gearbox section of the aircooled manual for reference?  How similar are they?
Andi
« Reply #20 on: May 09, 2009, 11:15:58 PM »
Just the same, only the differential differs: 8/39 ac, 9/39 wc. And, of course, the clutch-housing.
Adzdum
« Reply #21 on: May 10, 2009, 11:42:11 PM »
Didn't get around to doing anything with the engine/gearbox this weekend.  Maybe next weekend if I can get some time to myself.
However the oil I could see seaping out from between the engine and gearbox seems to be getting worse as a large oil puddle has now appeared on the driveway!  ::)
Can anyone pont me in the direction of new oil seals?.. I've looked around online but they dont seem readily available?
Can you get all the gear box seals in a pack? or all seperate?
Cheers,
Adz
« Reply #22 on: May 10, 2009, 11:59:15 PM »
e bay!
Adzdum
« Reply #23 on: May 11, 2009, 03:38:08 PM »
I'll have to keep on looking as I've not seen one in quite a while.
Is it a seperate gasket set for the aircooled engine and the BIS, or are they one in the same?
Adzdum
« Reply #25 on: May 11, 2009, 09:35:59 PM »
Cheers Dude!
We probably do have some dealers like that here.. But I'm new to the 126 scene!.. hence all the stoopid questions  ::) Sorry
Crxsprocket
« Reply #26 on: May 18, 2009, 08:31:41 PM »
Although a recent joiner to this forum we are long time bambino owners, owning three 500's and six 126's as second cars within the family over many years  :)...and out of a need to keep them running economically I always repaired them myself...
The symptoms you have defo indicate knackered gearbox rubber mountings, having experienced the same on 2 of our cars in the past...allowing the engine torque to oscillate the engine/gearbox unit against the bodywork with each crank cycle, it also this action of turning the gearbox whilst the gearstick remains in 1st position that taps the gear selector into neutral... ;D
I would suggest changing the mounts first, before diving into gearbox changes, etc...Lots of 500/126's seep oil via the rear crank oil seal..However, any oil will either drip down whilst engine is stopped or get flung against bellhousing when engine is running...then over time drip out of bellhousing at lowest point, seldom to contaminate or damage the clutch plate.
If this seepage is excessive or a bother....the gearbox removal is an easy task by taking weight of engine/gearbox unit on trolley jack and drawing out of car rear... [-/
Adzdum
« Reply #27 on: May 22, 2009, 10:01:42 AM »
Ummmm... another stupid question.. but how the hell am I meant to fill the gearbox oil up with the box level.. if the filler plug is almost unreachable?  If I'm looking at the right plug its the square one behind the driveshaft on the right hand side? I believe you fill it till the oil starts to come back out of the hole?
I can get to the plug when the car is on ramps.. but on the drive way I'm struggling to see how I'd get the oil to the hole?
Also can anyone recommend a suitable gearbox and engine oil for the BIS?
Crxsprocket: Thanks for the post, I STILL havn't tried the car with new mounts on.. but fingers crossed!
Thanks again all!
Adzdum
« Reply #29 on: May 22, 2009, 04:47:15 PM »
OOOhhhh... cool stuff!!!  8)
All I need now is the right oil to go in it!  :-
