Author Topic: Suspension probs  (Read 2497 times)
Suspension probs
« on: May 01, 2009, 09:09:16 AM »
Its been a while since i wrote in this section...
Well, i have a problem with the rear suspension, the car is noticably lower on the left hand side than on the right, and when moderately laden the inner side of the rim starts scratching the body work, i checked and the spring looks just fine, not broken anywhere, what else could cause this? thanx ;)
Re: Suspension probs
« Reply #1 on: May 01, 2009, 11:45:13 AM »
 Is there any chance you put on some weight Gordan ??? Maybe all that beer drinking took it`s toll... ;)
 Otherwise not sure. How is the shock absorber? Possibly corroded spring mounts? hmmm...
« Reply #2 on: May 01, 2009, 12:18:14 PM »
 :D im not cutting down on beer  >:( :)
i dont know much about the shock absorber, i looked round it but it doesnt seem to have leaked, i could be wrong... all i know its not a corrosion problem, it all looks healty...  :oops: :oops:
might have to consult some profesionals...
« Reply #3 on: May 01, 2009, 05:38:49 PM »
I think it could just be fair ware and tear, you could try swopping the springs over left and right and see if that cures the problem or if your feelling flush :D a new set of rear springs ;)
« Reply #4 on: May 01, 2009, 07:55:35 PM »
sorry mate youve worn it out!
« Reply #5 on: May 01, 2009, 09:54:19 PM »
i dont mind replacing things, but i need to be certain what to replace, so you lads say its the springs? cool, ill get a new set then... thanx [-/
