Author Topic: abarth type rocker cover  (Read 4377 times)
« on: April 28, 2009, 12:23:05 PM »
i have an abarth type rocker cover and have fitted it to my engine , however i found that as soon as i ran the engine it started pushing oil through the vent pipe and half filled up my catch tank (not such a silly idea now).
 the only reason i can see is that the splash guard inside the rocker cover is not doing a good enough job as it is a different design to the original or because the vent has a smaller diameter bore meaning somehow there is an increase in pressure . this is a very popular bolt on part that is used often so i wonder has anyone else had any problems such as mine?
Andi
Re: abarth type rocker cover
« Reply #1 on: May 05, 2009, 09:40:46 AM »
i once had mounted such a cover, too, but not for a long time, as i came to the realization, that it was garbage. It has no ventilationsystem like the original one, and, as you mentioned, the pipe is smaller, which increases pressure inside the engine and causes leakage. Those covers are just looking good, not more. The best cover still is the original one.
« Reply #2 on: May 05, 2009, 10:13:33 AM »
can you not fit a bigger vent pipe?
« Reply #3 on: May 05, 2009, 10:41:27 AM »
well i did think about drilling the bore out to a bigger size but to be honest i cant really be bothered as its only "gucci" and not "go fast" as andi seems to have been down the same path
Andi
« Reply #4 on: May 05, 2009, 01:54:18 PM »
"gucci" could not look better... [-/
http://img16.imageshack.us/img16/2993/schieberad003.jpg
BTW: This mat on your 126 looks incredible good!
« Last Edit: May 05, 2009, 01:59:13 PM by Andi »
Tomasz
« Reply #5 on: May 06, 2009, 08:10:22 AM »
You should drill it out, they look cool.  Failing that, i may be interested in buying it off you!
Tomasz
« Reply #6 on: May 06, 2009, 08:11:50 AM »
andi - Nice looking engine btw - did you custom make your engine casing, it looks really neat.  Is there still a thermostat in there?
« Last Edit: May 06, 2009, 08:15:56 AM by Tomasz »
« Reply #7 on: May 06, 2009, 09:54:55 PM »
 Took me ages to download the photo of the engine for some reason, but I have to say it looks great. Better than gucci!!! [-/
 Have you got a video of it somewhere?
Andi
« Reply #8 on: May 07, 2009, 06:00:08 AM »
casing is powdered black, thermostat is right in place, why shouldn't it? Sorry, no video, i've no idea what should i film???
Got 3 sets of main jets yesterday, 'm gonna try to find a good setup today, then probably i could record a sound check  :salute:
« Reply #9 on: May 07, 2009, 09:02:27 AM »
am i right in thinking that the fan/alternator housing and thermostat housing are from a panda 30?
only i have never seen a 126 with this shape of housings , i think its that what has confused some of us?
if thats the case where did you buy these as i cannot find anything about panda 30 engine cooling housings anywhere!
 and the engine bay looks well pukka by the way!
« Reply #10 on: May 07, 2009, 09:50:42 AM »
 I ment a video of how the engine sounds like ;) Do you know what sort of bhp it is producing?
 Mick I found this pics of the Panda 30 engine. The housing and the fan set up is completely different. So I guess Andi`s are "custom" made...
 http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&item=330320311142QQssPageNameZMERC_VI_RCRX_Pr4_PcY_BIN_IT&refitem=330320287359&itemcount=4&refwidgetloc=active_view_item&usedrule1=CrossSell_LogicX&refwidgettype=cross_promot_widget&_trksid=p284.m184&_trkparms=algo%3DCRX%26its%3DS%252BI%26itu%3DUCI%252BSI%26otn%3D4
« Reply #11 on: May 07, 2009, 11:07:30 AM »
looking at that engine brings me to this question ,what way does the engine turn? and  has anyone stuck this complete powerplant into a  500 or 126?
« Reply #12 on: May 07, 2009, 12:45:22 PM »
 I think the engine turns anticlockwise. So not sure if you could even use it with the Panda box in the 126, as it is front wheel drive. I`m confused now :oops:
« Reply #13 on: May 07, 2009, 01:31:46 PM »
I recently purchased a number of Fiat 500 / 126 items from a guy who had imported a 500 from Holland that had a 126 engine fitted . He modified the engine & one of the leftover parts was an original Fiat Air Filter assembly that bolted on to the top of the fan housing like the one in Andi's picture. Surplus to requirements I put it on eBay as a mystery item. I then got an e-mail from a guy in Italy identifying it as the type of Air Filter that was fitted to the 126 engine in German cars. I modified the listing & a guy in Austria bought it . The things I do for 99p  ::)
The EU , what's that all about then  ???
On a completely different tack, I bought some bits from a Croatian guy at the weekend. Had a great chat with him about Fiat cars . He told me that his ex had a Fiat 500 before & after the "troubles" Aparently the car was often used for target practice & was totaly riddled with bullet holes but still drove OK  </8
Andi
« Reply #14 on: May 07, 2009, 01:40:17 PM »
Panda Engine turns left, as mentioned. Allthough all things on your island are on the wrong side, this engine really won't fit into our 126  ;D
My housings are from a very german issue: The square head-engine. This was specially build for us to avoid emission from a leak coming to the heating. This was neccesary for approval. Air for heating only comes from the cylinderhead, not from the gasketarea and the cylinders. Even the crankcase is a little different, to take the housing.
If you are looking for such a housing on german sites, you have to search for "Eckkopf". I just found one for a dude, who upgrades to Panda, too, but those housings are getting rare, and mostly they are broken from vibrations.
It does not fit 1:1, but it's easy to do. Only alternator-housing needs about half an hour of work, thermostat housing is ok.
