Author Topic: Wheels in steel !  (Read 2063 times)
Nat
Wheels in steel !
« on: April 27, 2009, 01:55:20 PM »
Hiya all, can i have some enlightenment on tyre/rim swops. I have a bis on the std wheels but have trouble finding the correct tyres plus- i'm going across Europe soon and would ideally like 145/70/13 on a 4.5j rim with a little more offset at the rear. Anyone tried Lada Riva/ Fiat 124 or similar ? If i have no joy i'm going to have to do a cut and shut on suitable rims with bis centres- because aesthetically they're nice .(i Know what you're thinking but i can weld !) There's no need for larger/wider/heavier wheels at present as i'm with the 2cyl for a while but i have plans for another engine later. Any which way, it's just not on to 'overtyre' a car cos it just don't work eh. Thanks all, any help much appreciated. Oh and it's Worcestershire to Rome people, oh HELL yeah i may well be crazy but, anyone can jump on a plane.  :P
Re: Wheels in steel !
« Reply #1 on: April 27, 2009, 08:47:27 PM »
England to Italy? now thats a proper adventure right there... good luck.
As for the tires, not sure i understood the question completely, all i can tell you is i had 145/80/13 tires on my std rims and worked perfectly, so you could get those, if going alloy try locating some cinquecento sporting rims or the sorts, they fit right on an provide better traction due to larger width, and one can never have too much traction.. i should know...  :oops: :D
« Reply #2 on: April 27, 2009, 11:16:23 PM »
if you are going to cut up and reweld your steeleys then i hope you have done it before as its a pretty skilled job as they have to be spot on and balanced without tyres .
Nat
« Reply #3 on: April 28, 2009, 03:03:29 PM »
I know, i know it's a skilled job alright but i've been restoring cars all my life along with racecar prep/builds from 1920's to date.. etc etc ! All in a days work. Obviously i'd prefer the easy option i.e X19 4.5x13 rims would be a choice for a start. It's just that ideally a 4j rim is just that little bit too narrow for a 145 even though there's no probs in fitting them along with even a 155 but, i'd prefer that the tyres didn't roll around too much and the suspension did the work. Thanks for the input so far, time is of the essence so i may well have to put 145's on the 4j's for now. Adjustable dampers are going on the back along with at present ,cut springs but i don't like that idea and have priced up some coiled to my spec along with a rising rate. Front will add a leaf and turn bottom leaf 180 deg. Too cheap to buy one, it's all on a STRICT budget. Whatever can be made will be made. Thanks all
« Reply #4 on: April 28, 2009, 10:10:04 PM »
the x19 rims are ok but on a budget you will only find brittle kerbed rims that are better off in the skip. i got some cinq alloys for 40 notes on e bay try your local scrappy as theres loads of kids driving fiats into trees every week.
« Reply #5 on: April 29, 2009, 06:28:03 AM »
 :) If you want cheap then standard Panda or Uno wheels will go straight on.
Tomasz
« Reply #6 on: April 29, 2009, 08:06:49 AM »
Did x1/9's have 4.5j?  I assumed they would all have 5j.  I am currently in the process of buying some mirafiori wheels from a retro rides forum user.  These are in steel but are 5 wide and very nice they are too. There is a pic of them on his uno on this thread: http://retrorides.proboards.com/index.cgi?board=readersrides&action=display&thread=40969&page=3
Great trip, good luck.  We drove to Montenegro and back last year.  We were going to do it in an MGA but only got it on the road the day we were leaving so thought it best just to take a vw polo instead!
Nat
« Reply #7 on: April 29, 2009, 09:00:21 AM »
Hiya all, yes X19 had 4.5j rims from 128 believe it or not (strange though it had a pos offset!) Totally forgot about those 131/2 rims very nice they are too. Poss when i've done the engine swop they'll be fine. I'll keep a look out for those most definately. Montenegro !!! AH man, that's a place i'd like to do it looks stunning there- i'm jealous. Panda/uno have the front drive i.e inset balance to the flange/rim the hub is further out than the rim. Thanks for all and any input and hopefully no-one thinks i'm teaching them to 'suck eggs' as it were.
