Author Topic: Bis/Cinq instrument pannel swap?  (Read 1756 times)
« on: April 26, 2009, 07:10:20 AM »
Ive been looking at my bros instrument pannel (in the cinquecento), and i got a crazy idea to get one and fit it to my bis, i think it should fit perfectly, cos it was fitted to later el models, and its much nicer and much more modern. What do you guys think? The only diff i see is that the bis speedo reads max 140km/h and the cinq goes up to 160...
Cinquecento:
 Bis:
126 el
Re: Bis/Cinq instrument pannel swap?
« Reply #1 on: April 26, 2009, 09:47:33 PM »
Should be O.K. [-/ are they cable drive ??? You can convert them to white dials as well ;D
« Reply #2 on: April 27, 2009, 05:45:24 AM »
I think they are cable driven, ill have to have a peek in the cinq while my bro is not around, he wont let me take it apart, cant see why...  :oops: :oops: :D
« Reply #3 on: April 28, 2009, 09:39:56 PM »
Now heres something interesting ive just found, take a look at this:
its just the same as the cinq sporting instrument panel, but in fact its from a 126 elx, an aircooled! it had a rev counter, and a temp meter, well thats what a italian site said anyways, now im really going for it, im going to get one of theese and try to combine it with my bis, just dont know if the rev counter will work, since the cinq has 4 cylinders...
Adzdum
« Reply #4 on: May 02, 2009, 02:47:47 PM »
Hey Gordan... sounds like a cool project!
I'm in the process of trying something similar but fitting an S2000 instrument panel in to my Integra-R. Problem with the later cars is all the electonics involved!  :o
Would be intersted in hearing how difficult this would be to do.  All though personally the curent 126 panel has a certain charm about it so I'd probably stick with the one she has.  I like the way the gauges wobble around as you drive.. not knowing exactly how fast your going or how much fuel is left is part of the fun!  ;)
Try and do us a 'how to' guide! :)
Good Luck!
Adz
« Reply #5 on: May 03, 2009, 01:48:25 AM »
Thx dude, is there by some chance a diference in the number of cyls between your integra and the s2000, cos im still puzzled how and if its going to work... the main problem is acquiring the panel (cant wait to go to italy) then the rest should fall in place. the main reason im doing this is becouse i dont think there will be too much tinkering with the electronics, and the sporting gauges look more modern, and im all about modern :D
