Hi guys,
I have slight problem with the installing of my starter cable. I'll explain. The cable is still intact, and connected at both ends. The problem is the outer slieve seems to have come adrift at the starter end, simulating a broken cable when i pull the lever in my air-cooled. There is a metal type thingy stiil attached, which looks like it might go in some-where and twist through 90 degrees to locate, but I cant find where it locate.Its no biggie as a piece of 2x1 is doing the the job, have tried Haynes and Autobooks manuals, but no joy.
Any-one any ideas?
Thanks in advance, Dessie.
